74HC595
Overview
Generally, there are two ways to drive a single 7-segment display. One way is to connect its 8 pins directly to eight ports on the Uno board, which we have done previously. Or you can connect the 74HC595 to three ports of the UNO board and then the 7-segment display to the 74HC595. In this experiment, we will use the latter. By this way, we can save five ports – considering the Uno board’s limited ports, this is very important. Now let’s get started!
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
In the experiment MR (pin10) is connected to 5V (HIGH Level) and OE (pin 1) to GND (LOW Level). Therefore, the data is input into the rising edge of SHcp and enters the memory register through the rising edge. We use the shiftout() function to output a 8-bit data to the shift register through DS. In the rising edge of the SHcp, the data in the shift register moves successively one bit in one time, i.e. data in Q1 moves to Q2, and so forth. In the rising edge of STcp, data in the shift register moves into the memory register. All data will be moved to the memory register after 8 times. Then the data in the memory register is output to the bus (Q0-Q7). So the 16 characters are displayed in the 7-segment in turn.
You can open the file
29-74hc595.inounder the path ofelite-explorer-kit-main\basic_project\29-74hc595directly.Or copy this code into Arduino IDE.
1/*
2 Control 74HC595 Shift Register to display numbers and letters (0-9, A-F)
4 Board: Arduino Uno R4
5 Component: 74HC595
6*/
7
8const int STcp = 12; //Pin connected to ST_CP of 74HC595
9const int SHcp = 8; //Pin connected to SH_CP of 74HC595
10const int DS = 11; //Pin connected to DS of 74HC595
11//display 0,1,2,3,4,5,6,7,8,9,A,b,C,d,E,F
12int datArray[16] = { 252, 96, 218, 242, 102, 182, 190, 224, 254, 246, 238, 62, 156, 122, 158, 142 };
13
14void setup() {
15 //set pins to output
16 pinMode(STcp, OUTPUT);
17 pinMode(SHcp, OUTPUT);
18 pinMode(DS, OUTPUT);
19}
20void loop() {
21 //loop from 0 to 256
22 for (int num = 0; num < 16; num++) {
23 digitalWrite(STcp, LOW); //ground ST_CP and hold low for as long as you are transmitting
24 shiftOut(DS, SHcp, MSBFIRST, datArray[num]);
25 //return the latch pin high to signal chip that it
26 //no longer needs to listen for information
27 digitalWrite(STcp, HIGH); //pull the ST_CPST_CP to save the data
28 delay(1000); //wait for a second
29 }
30}
After uploading the codes to the uno board, you should now see the 7-segment display from 0 to 9 and A to F.
Code Analysis
Set the array elements
int datArray[16] = {252, 96, 218, 242, 102, 182, 190, 224, 254, 246, 238, 62, 156, 122, 158, 142};
This array stores the data of the 16 characters from 0 to F. 252 stands for 0, which you can calculate by yourself. To display 0, the segment g (the middle one) of the 7-segment display must be low level (dim).
Since the segment g is connected to Q1 of the 74HC595, set both Q1 and DP (the dot) as low level and leave the rest pins as high level. Therefore, the values of Q7 Q6 Q5 Q4 Q3 Q2 Q1 Q0 are 1 1 1 1 1 1 0 0.
Change the binary numbers into decimal ones: 1x27+1x26+1x25+1x24+1x23+1x22+0x21+1x20=252.
So that’s the value for the number 0 to be displayed. You can calculate other characters similarly.
Display 0-F in the 7-segment display
for(int num = 0; num < 16; num++)
digitalWrite(STcp,LOW); //ground ST_CP and hold low for as long as you are transmitting
shiftOut(DS,SHcp,MSBFIRST,datArray[num]);
digitalWrite(STcp,HIGH); //pull the ST_CPST_CP to save the data
Set STcp as low level first and then high level. It will generate a rising edge pulse of STcp.
shiftOut() is used to shift out a byte of data one bit at a time, which means to shift a byte of data in dataArray[num] to the shifting register with the DS pin. MSBFIRST means to move from high bits.
After digitalWrite(STcp,HIGH) is run, the STcp will be at the rising edge. At this time, the data in the shift register will be moved to the memory register.
A byte of data will be transferred into the memory register after 8 times. Then the data of memory register is output to the bus (Q0-Q7). You will see a character is displayed on the 7-segment. Then delay for 1000ms. After that line, go back to for(). The loop repeats until all the characters are displayed in the 7-segment display one by one after
16 times.
