Keypad
Overview
In this lesson, you will learn to use Keypad. Keypad can be applied into various kinds of devices, including mobile phone, fax machine, microwave oven and so on. It is commonly used in user input.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Keypad
../_images/21-keypad_bb.png
Schematic Diagram
../_images/21_keypad_schematic.png
  • You can open the file 21-keypad.ino under the path of elite-explorer-kit-main\basic_project\21-keypad directly.
  • To install the library, use the Arduino Library Manager and search for “Adafruit Keypad” and install it.
21-keypad.ino
 1/*
 2  The code use an Adafruit Keypad and display keypress events via the Serial Monitor.
 3  It initializes the keypad with a 4x4 layout, where each key is represented by a
 4  specific character. It continuously checks for keypad events (key press or release)
 5  and prints the corresponding key and event status to the Serial Monitor.
 7  Board: Arduino Uno R4
 8  Component:  Keypad
 9  Library: https://github.com/adafruit/Adafruit_Keypad (Adafruit Keypad by Adafruit)
10*/
11
12// Include the Adafruit_Keypad library
13#include "Adafruit_Keypad.h"
14
15// Define the number of rows and columns for the keypad
16const byte ROWS = 4;
17const byte COLS = 4;
18
19// Define the characters mapped to each button on the 4x4 keypad
20char keys[ROWS][COLS] = {
21  { '1', '2', '3', 'A' },
22  { '4', '5', '6', 'B' },
23  { '7', '8', '9', 'C' },
24  { '*', '0', '#', 'D' }
25};
26
27// Define the Arduino pins connected to the row pinouts of the keypad
28byte rowPins[ROWS] = { 2, 3, 4, 5 };
29// Define the Arduino pins connected to the column pinouts of the keypad
30byte colPins[COLS] = { 8, 9, 10, 11 };
31
32// Initialize a custom keypad instance
33Adafruit_Keypad myKeypad = Adafruit_Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
34
35// Setup function
36void setup() {
37  // Initialize Serial communication at 9600 baud rate
38  Serial.begin(9600);
39  // Initialize the custom keypad
40  myKeypad.begin();
41}
42
43// Main loop function
44void loop() {
45  // Update the state of keys
46  myKeypad.tick();
47
48  // Check if there are new keypad events
49  while (myKeypad.available()) {
50    // Read the keypad event
51    keypadEvent e = myKeypad.read();
52    // Print the key that triggered the event
53    Serial.print((char)e.bit.KEY);
54    // Print the type of event: pressed or released
55    if (e.bit.EVENT == KEY_JUST_PRESSED) Serial.println(" pressed");
56    else if (e.bit.EVENT == KEY_JUST_RELEASED) Serial.println(" released");
57  }
58
59  delay(10);
60}
After uploading the codes to the UNO board, on the serial monitor, you can see the value of the key currently pressed on the Keypad.
Code Analysis
  1. Including the Library
    We start by including the Adafruit_Keypad library, which allows us to easily interface with the keypad.
  2. Keypad Configuration
    • The ROWS and COLS constants define the dimensions of the keypad.
    • keys is a 2D array storing the label for each button on the keypad.
    • rowPins and colPins are arrays that store the Arduino pins connected to the keypad rows and columns.
  3. Initialize Keypad
    Create an instance of Adafruit_Keypad called myKeypad and initialize it.
  4. setup() Function
    Initialize Serial communication and the custom keypad.
      Serial.begin(9600);
      myKeypad.begin();
  5. Main Loop
    Check for key events and display them in the Serial Monitor.
      myKeypad.tick();
      delay(10);
