Button
Overview
In this lesson, you will learn about controlling an LED using a button with Arduino. Buttons and LEDs are fundamental components in a wide range of electronic devices, such as remote controls, flashlights, and interactive installations. In this setup, a button is used as an input device to control the state of an LED, which serves as an output device.
The button is connected to pin 12 on the Arduino Uno R4 board, and the LED is connected to pin 13. When the button is pressed, a signal is sent to the Arduino, triggering the LED to turn on. Conversely, when the button is released, the LED turns off. This simple yet effective mechanism can be the basis for more complex projects, such as home automation systems, interactive displays, and much more.
By the end of this lesson, you will understand how to read input from a button and use it to control an LED, thereby gaining a foundational understanding of input/output operations with Arduino.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
Capacitor
Button
../_images/18-button_bb.png
Schematic Diagram
Connect one end of the buttons to pin 12 which connects with a pull-down resistor and a 0.1uF (104) capacitor (to eliminate jitter and output a stable level when the button is working). Connect the other end of the resistor to GND and one of the pins at the other end of the button to 5V. When the button is pressed, pin 12 is 5V (HIGH) and set pin 13 (integrated with an LED) as High at the same time. Then release the button (pin 12 changes to LOW) and pin 13 is Low. So we will see the LED lights up and goes out alternately as the button is pressed and released.
../_images/18_button_schematic.png
  • You can open the file 18-button.ino under the path of elite-explorer-kit-main\basic_project\18-button directly.
18-button.ino
 1/*
 2  This code controls an LED using a button. When the button is pressed,
 3  the LED turns on; when the button is released, the LED turns off.
 5  Board: Arduino Uno R4
 6  Component: Button and LED
 7*/
 8
 9const int buttonPin = 12;  // Pin number for the button
10const int ledPin = 13;     // Pin number for the LED
11
12int buttonState = 0;  // Variable to hold the current state of the button
13
14// Setup function runs once when the board starts
15void setup() {
16  pinMode(buttonPin, INPUT);  // Initialize buttonPin as an input pin
17  pinMode(ledPin, OUTPUT);    // Initialize ledPin as an output pin
18}
19
20// Main loop function runs repeatedly
21void loop() {
22  // Read the current state of the button
23  buttonState = digitalRead(buttonPin);
24
25  // Check if the button is pressed (HIGH)
26  if (buttonState == HIGH) {
27    digitalWrite(ledPin, HIGH);  // Turn the LED on
28  } else {
29    digitalWrite(ledPin, LOW);  // Turn the LED off
30  }
31}
Code Analysis
  1. Define Constants and Variables
    In this segment, the pin numbers for the button and the LED are defined. Also, a variable buttonState is declared to hold the current state of the button.
  2. Setup Function
    The setup() function runs once when the Arduino board starts. The pin modes for the button and the LED are set using the pinMode function.
  3. Main Loop
    The loop() function runs repeatedly. Inside this loop, the digitalRead() function is used to read the state of the button. Depending on whether the button is pressed or not, the LED is turned on or off.
      } else {
