Power Supply Module
To protect the Power Supply Module’s Power Pack, please fully charge it before using it for the first time.
When we need a large current to drive a component, which will severely interfere with the normal work of Arduino UNO board. Therefore, we separately supply power for the component by this module to make it run safely and steadily.
You can just plug it in the breadboard to supply power. It provides a voltage of 3.3V and 5V, and you can connect either via a jumper cap included.
Features and specifications
Charge Input: USB Type-C, 5V
Output Voltage: 5V, 3.3V (adjustable via jumpers. 0V, 3.3V, and 5V configuration)
Output Current: 5V/1.5A, 3.3V/1A
ON-OFF Switch Available
Two Independent Channel
USB (Type-A) Output Available
Battery: 3.7V Power Pack, 500mAh
Dimension: 52mm x 32mm x 24mm (L x W x H)
Example
Motor (Basic Project)
Water Pump (Basic Project)
Stepper Motor (Basic Project)
Smart Fan (Fun Project)
Plant Monitor (Fun Project)
Access Control System (Fun Project)
GAME - Pong (Fun Project)
