Infrared Receiver
Overview
An infrared-receiver is a component that receives infrared signals and can independently receive infrared ray and output signals compatible with TTL level. It’s similar with a normal plastic-packaged transistor in size and it is suitable for all kinds of infrared remote control and infrared transmission.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
Infrared Receiver
../_images/22-ir_receiver_bb.png
Schematic Diagram
../_images/22_irrecv_schematic.png
  • You can open the file 22-ir_receiver.ino under the path of elite-explorer-kit-main\basic_project\22-ir_receiver directly.
22-ir_receiver.ino
 1/*
 2  This Arduino receive and decode infrared (IR) signals from a remote control. It uses
 3  the IRremote library to receive the IR signals and map them to corresponding keys like
 4  numbers, mathematical operations, and other function keys.
 6  Board: Arduino Uno R4
 7  Component: Infrared Receiver
 8  Library: https://github.com/Arduino-IRremote/Arduino-IRremote (IRremote by shirriff, z3t0, ArminJo)
 9*/
10
11// Include the necessary libraries
12#include <IRremote.h>
13
14// Define the pin numbers for the IR receiver
15const int IR_RECEIVE_PIN = 2;
16
17void setup() {
18  Serial.begin(9600);                                     // Start serial communication at 9600 baud rate
19  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);  // Start the IR receiver
20}
21
22void loop() {
23  // Check if there is any incoming IR signal
24  if (IrReceiver.decode()) {
25    IrReceiver.printIRResultShort(&Serial);                 // Print the received data in one line
26    // Serial.println(IrReceiver.decodedIRData.command, HEX);  // Print the command in hexadecimal format
27    Serial.println(decodeKeyValue(IrReceiver.decodedIRData.command));  // Map and print the decoded IR signal to corresponding key value
28    Serial.println(IrReceiver.decodedIRData.decodedRawData, HEX); // Print "old" raw data
29    IrReceiver.resume();  // Enable receiving of the next value
30  }
31}
32
33// Function to map received IR signals to corresponding keys
34String decodeKeyValue(long result) {
35  // Each case corresponds to a specific IR command
36  switch (result) {
37    case 0x16:
38      return "0";
39    case 0xC:
40      return "1";
41    case 0x18:
42      return "2";
43    case 0x5E:
44      return "3";
45    case 0x8:
46      return "4";
47    case 0x1C:
48      return "5";
49    case 0x5A:
50      return "6";
51    case 0x42:
52      return "7";
53    case 0x52:
54      return "8";
55    case 0x4A:
56      return "9";
57    case 0x9:
58      return "+";
59    case 0x15:
60      return "-";
61    case 0x7:
62      return "EQ";
63    case 0xD:
64      return "U/SD";
65    case 0x19:
66      return "CYCLE";
67    case 0x44:
68      return "PLAY/PAUSE";
69    case 0x43:
70      return "FORWARD";
71    case 0x40:
72      return "BACKWARD";
73    case 0x45:
74      return "POWER";
75    case 0x47:
76      return "MUTE";
77    case 0x46:
78      return "MODE";
79    case 0x0:
80      return "ERROR";
81    default:
82      return "ERROR";
83  }
84}
  • The IRremote library is used here, you can install it from the Library Manager.
    ../_images/22_irrecv_lib.png
  • There is a transparent plastic piece at the back of the remote control to cut off the power and pull it out before you use the remote control.
Code Analysis
This code is designed to work with an infrared (IR) remote control using the IRremote library. Here’s the breakdown:
  1. Including the library and defining constants. First, the IRremote library is included, and the pin number for the IR receiver is defined as 2.
  2. Initializes serial communication at a baud rate of 9600. Initializes the IR receiver on the specified pin (IR_RECEIVE_PIN) and enables LED feedback (if applicable).
  3. The loop runs continuously to process incoming IR remote signals.
        // IrReceiver.printIRResultShort(&Serial);                 // Print the received data in one line
    • Checks if an IR signal is received and successfully decoded.
    • Decodes the IR command and stores it in decodedValue using a custom decodeKeyValue() function.
    • Prints the decoded IR value to the serial monitor.
    • Resumes IR signal reception for the next signal.
  4. Helper function to map received IR signals to corresponding keys
    ../_images/22_irrecv_key.png
      switch (result) {
        case 0x16:
          return "0";
        case 0xC:
          return "1";
        case 0x18:
          return "2";
        case 0x5E:
          return "3";
        case 0x8:
          return "4";
        case 0x1C:
          return "5";
        case 0x5A:
          return "6";
        case 0x42:
          return "7";
        case 0x52:
          return "8";
        case 0x4A:
          return "9";
        case 0x9:
          return "+";
        case 0x15:
          return "-";
        case 0x7:
          return "EQ";
        case 0xD:
          return "U/SD";
        case 0x19:
          return "CYCLE";
        case 0x44:
        case 0x43:
          return "FORWARD";
        case 0x40:
          return "BACKWARD";
        case 0x45:
          return "POWER";
        case 0x47:
          return "MUTE";
        case 0x46:
          return "MODE";
        case 0x0:
          return "ERROR";
        default:
          return "ERROR";
