MPU6050
Overview
In this tutorial, you’ll learn to interface the GY-87 IMU module with an Arduino Uno, focusing on the MPU6050 sensor. We’ll cover initializing the MPU6050 and displaying its accelerometer, gyroscope, and temperature data on the Serial Monitor. This lesson is essential for projects needing motion and temperature sensing, like robotics, gesture-controlled devices, and interactive art installations.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
You can open the file
09-gy87_mpu6050.inounder the path ofelite-explorer-kit-main\basic_project\09-gy87_mpu6050directly.Or copy this code into Arduino IDE.
To install the library, use the Arduino Library Manager and search for “Adafruit MPU6050” and install it.
1/*
2 This Arduino code is designed for interfacing with the GY-87 IMU module, focusing
3 specifically on the MPU6050 sensor, which includes an accelerometer and a gyroscope.
4 The code initializes the MPU6050 sensor and prints its accelerometer, gyroscope, and
5 temperature readings to the Serial Monitor at regular intervals.
7 Board: Arduino Uno R4
8 Component: GY-87 IMU Module
9 Library: https://github.com/adafruit/Adafruit_MPU6050 (Adafruit MPU6050 by Adafruit)
10*/
11
12// Include required libraries
13#include <Adafruit_MPU6050.h>
14#include <Adafruit_Sensor.h>
15#include <Wire.h>
16
17// Initialize sensor objects
18Adafruit_MPU6050 mpu;
19
20void setup() {
21 // Initialize the serial communication with a baud rate of 9600
22 Serial.begin(9600);
23
24 // Initialize the MPU6050 sensor (accelerometer and gyroscope)
25 initializeMPU6050();
26}
27
28void loop() {
29 // Print MPU6050 data
30 printMPU6050();
31
32 delay(500);
33}
34
35
36void initializeMPU6050() {
37 // Check if the MPU6050 sensor is detected
38 if (!mpu.begin()) {
39 Serial.println("Failed to find MPU6050 chip");
40 while (1)
41 ; // Halt if sensor not found
42 }
43 Serial.println("MPU6050 Found!");
44
45 // set accelerometer range to +-8G
46 mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
47
48 // set gyro range to +- 500 deg/s
49 mpu.setGyroRange(MPU6050_RANGE_500_DEG);
50
51 // set filter bandwidth to 21 Hz
52 mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
53
54 Serial.println("");
55 delay(100);
56}
57
58void printMPU6050() {
59
60 Serial.println();
61 Serial.println("MPU6050 ------------");
62
63 /* Get new sensor events with the readings */
64 sensors_event_t a, g, temp;
65 mpu.getEvent(&a, &g, &temp);
66
67 /* Print out the values */
68 Serial.print("Acceleration X: ");
69 Serial.print(a.acceleration.x);
70 Serial.print(", Y: ");
71 Serial.print(a.acceleration.y);
72 Serial.print(", Z: ");
73 Serial.print(a.acceleration.z);
74 Serial.println(" m/s^2");
75
76 Serial.print("Rotation X: ");
77 Serial.print(g.gyro.x);
78 Serial.print(", Y: ");
79 Serial.print(g.gyro.y);
80 Serial.print(", Z: ");
81 Serial.print(g.gyro.z);
82 Serial.println(" rad/s");
83
84 Serial.print("Temperature: ");
85 Serial.print(temp.temperature);
86 Serial.println(" degC");
87
88 Serial.println("MPU6050 ------------");
89 Serial.println();
90}
Code Analysis
Include Libraries
The
Adafruit_MPU6050,Adafruit_Sensor, andWirelibraries are included for sensor interfacing and communication.#include <Adafruit_MPU6050.h> #include <Adafruit_Sensor.h> #include <Wire.h>
Initialize Sensor Object
An object of the Adafruit_MPU6050 class is created to represent the MPU6050 sensor.
Setup Function
Initializes serial communication and calls the function to initialize the MPU6050 sensor.
void setup() { Serial.begin(9600); initializeMPU6050(); }
Loop Function
Repeatedly calls the function to print MPU6050 data with a delay of 500 milliseconds between each call.
void loop() { printMPU6050(); delay(500); }
Initialize MPU6050 Function
Checks if the MPU6050 is connected, sets accelerometer and gyro ranges, and configures the filter bandwidth.
void initializeMPU6050() { // Check if the MPU6050 sensor is detected if (!mpu.begin()) { Serial.println("Failed to find MPU6050 chip"); while (1) ; // Halt if sensor not found } Serial.println("MPU6050 Found!"); // set accelerometer range to +-8G mpu.setAccelerometerRange(MPU6050_RANGE_8_G); // set gyro range to +- 500 deg/s mpu.setGyroRange(MPU6050_RANGE_500_DEG); // set filter bandwidth to 21 Hz mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); Serial.println(""); delay(100); }
Print MPU6050 Data Function
Reads and prints the acceleration, gyroscope, and temperature data from the MPU6050 to the Serial Monitor.
void printMPU6050() { Serial.println(); Serial.println("MPU6050 ------------"); /* Get new sensor events with the readings */ sensors_event_t a, g, temp; mpu.getEvent(&a, &g, &temp); /* Print out the values */ Serial.print("Acceleration X: "); Serial.print(a.acceleration.x); Serial.print(", Y: "); Serial.print(a.acceleration.y); Serial.print(", Z: "); Serial.print(a.acceleration.z); Serial.println(" m/s^2"); Serial.print("Rotation X: "); Serial.print(g.gyro.x); Serial.print(", Y: "); Serial.print(g.gyro.y); Serial.print(", Z: "); Serial.print(g.gyro.z); Serial.println(" rad/s"); Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degC"); Serial.println("MPU6050 ------------"); Serial.println(); }
