Lesson 02: Capacitive Soil Moisture Module
In this lesson, you’ll learn how to use the Raspberry Pi Pico W to measure soil moisture levels using a capacitive sensor and an ADC (Analog to Digital Converter). This beginner-friendly project will introduce you to handling analog signals in MicroPython.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
from machine import ADC
# Initialize an ADC object on GPIO pin 26.
# This is typically used for reading analog signals.
sensor_AO = ADC(26)
# Continuously read and print sensor data.
value = sensor_AO.read_u16() # Read and convert analog value to 16-bit integer
print("AO:", value) # Print the analog value
time.sleep_ms(200) # Wait for 200 milliseconds before the next read
Code Analysis
Importing Libraries:
from machine import ADC import time
ADC Setup:
sensor_AO = ADC(26)
This code initializes an ADC object on GPIO pin 26. ADC is used to convert analog signals (from analog sensors) to digital data that the microcontroller can process.
Reading Sensor Data in a Loop:
while True: value = sensor_AO.read_u16() print("AO:", value) time.sleep_ms(200)
The
while Trueloop runs indefinitely, constantly reading data from the sensor. Theread_u16()method reads the analog value and converts it to a 16-bit unsigned integer. Theprintstatement displays this value. Thetime.sleep_ms(200)causes the loop to wait for 200 milliseconds before reading the sensor value again, preventing excessive data readings and console output.
