š Ready to explore and create with us? Click [here] and join today!
Lesson 07: Infrared Speed Sensor Moduleļ
In this lesson, you will learn how to use the Raspberry Pi Pico W to interface with an infrared speed sensor module. By connecting the sensor to GPIO 16, you will detect obstructions in real-time. The program monitors the sensor output, and when an obstruction is detected, it prints āObstruction detectedā to the console. If thereās no obstruction, it prints āUnobstructed.ā
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
Wiringļ
Codeļ
from machine import Pin
# Set GPIO 16 as an input pin to read the speed sensor
speed_sensor = Pin(16, Pin.IN)
if speed_sensor.value() == 1:
print("Obstruction detected")
print("Unobstructed")
time.sleep(0.1) # Short delay to reduce CPU usage
Code Analysisļ
Import Libraries:
This code begins by importing necessary libraries. The
machinelibrary is used to interact with the GPIO pins, and thetimelibrary is for adding delays in the program.from machine import Pin import time
Sensor Configuration:
The infrared speed sensor is connected to GPIO 16. Itās set as an input, meaning the Pi Pico W will read data from this pin.
Main Loop:
The
while True:loop creates an infinite loop. Inside this loop, the program continuously checks the sensorās value.If
speed_sensor.value()is 1, it means the sensor detects an obstruction. If it is 0, then there is no obstruction.while True: if speed_sensor.value() == 1: print("Obstruction detected") else: print("Unobstructed")
Delay to Reduce CPU Usage:
A short delay of 0.1 seconds is introduced in each iteration of the loop. This reduces the CPU usage by preventing the loop from running too rapidly.
time.sleep(0.1)
More
If an encoder is mounted on the motor, the rotational speed of the motor can be calculated by counting the number of times an obstruction passes the sensor within a specific period.
