Lesson 11: Photoresistor Module
In this lesson, you’ll learn how to connect a photoresistor module to the Raspberry Pi Pico W in order to measure light intensity. By linking the photoresistor to the analog input, you can read different analog values that correspond to varying light levels. This project is ideal for beginners and provides hands-on experience in utilizing analog inputs on the Raspberry Pi Pico W with MicroPython.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
../_images/Lesson_11_photoresistor_module_bb.png
import machine  # Hardware control library
import time  # Time control library
photoresistor = machine.ADC(26)  # Initialize ADC on pin 26
    value = photoresistor.read_u16()  # Read analog value
    print(value)  # Print the value
    time.sleep_ms(200)  # Delay of 200 ms between reads
Code Analysis
  1. Importing Libraries:
    The code begins by importing necessary libraries. The machine library is used for controlling hardware components, and the time library is used for managing time-related tasks such as delays.
  2. Initializing the Photoresistor:
    Here, we initialize the photoresistor. We use the machine.ADC class to create an ADC object on pin 26, where the photoresistor is connected. The ADC object will be used to read the analog values from the photoresistor.
  3. Reading from the Photoresistor:
    In this loop, the code continuously reads the analog value from the photoresistor using photoresistor.read_u16(). This method reads the value as a 16-bit unsigned integer. The value is then printed to the console.
  4. Adding a Delay:
    To prevent the code from running too quickly and flooding the console with data, a delay of 200 milliseconds is introduced after each read using time.sleep_ms(200).
