Lesson 22: Touch Sensor Module
In this lesson, you’ll learn how to connect a touch sensor to the Raspberry Pi Pico W in order to control an onboard LED. By using straightforward Python code, you’ll configure the touch sensor as an input device. When the sensor detects a touch, it will send a signal to turn on the LED, providing a visual indication that a touch has been detected. Conversely, when there’s no touch, the LED stays off.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
Touch Sensor Module
../_images/Lesson_22_touch_bb.png
from machine import Pin
# Set GPIO 16 as an input pin to read the touch sensor state
touch_sensor = Pin(16, Pin.IN)
# Initialize the onboard LED of the Raspberry Pi Pico W
led = Pin("LED", Pin.OUT)
    if touch_sensor.value() == 1:
        led.value(1)  # Turn on the LED
        print("Touch detected!")
        led.value(0)  # Turn off the LED
        print("No touch detected")
    time.sleep(0.1)  # Short delay to reduce CPU usage
Code Analysis
  1. Setting up the pins:
    Here, we import necessary libraries and set up GPIO pins. The touch sensor is connected to GPIO 16 as an input, and the onboard LED is configured as an output.
  2. Main loop and touch detection:
    In an infinite loop, the code constantly checks the state of the touch sensor. If a touch is detected (value equals 1), the LED is turned on and a message is printed. Otherwise, the LED remains off, and a different message is printed. A short delay is added to reduce CPU usage.
