Lesson 23: Ultrasonic Sensor Module (HC-SR04)
In this lesson, you will learn how to measure distances using the Raspberry Pi Pico W and an HC-SR04 ultrasonic sensor. You’ll find out how to connect the sensor to the Pico W and write a MicroPython script to control it. The lesson will cover calculating distances based on the time it takes for ultrasonic waves to reflect back from objects. This practical project provides insights into working with sensors, handling digital signals, and basic calculations in MicroPython, suitable for those interested in hardware interfacing with the Raspberry Pi Pico W.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
import machine # Import machine module for hardware control
import time # Import time module for delays
# Define pin numbers for ultrasonic sensor's TRIG and ECHO pins
TRIG = machine.Pin(17, machine.Pin.OUT) # TRIG pin set as output
ECHO = machine.Pin(16, machine.Pin.IN) # ECHO pin set as input
def distance():
# Function to calculate distance in centimeters
TRIG.low() # Set TRIG low
time.sleep_us(2) # Wait for 2 microseconds
TRIG.high() # Set TRIG high
time.sleep_us(10) # Wait for 10 microseconds
TRIG.low() # Set TRIG low again
# Wait for ECHO pin to go high
while not ECHO.value():
time1 = time.ticks_us() # Record time when ECHO goes high
# Wait for ECHO pin to go low
while ECHO.value():
time2 = time.ticks_us() # Record time when ECHO goes low
# Calculate the duration of the ECHO pin being high
during = time.ticks_diff(time2, time1)
# Return the calculated distance (using speed of sound)
return during * 340 / 2 / 10000 # Distance in centimeters
# Main loop
dis = distance() # Get distance from sensor
print("Distance: %.2f cm" % dis) # Print distance
time.sleep_ms(300) # Wait for 300 milliseconds before next measurement
Code Analysis
Importing libraries
The
machineandtimemodules are imported for accessing hardware-specific functions and time-related functions, respectively.import machine import time
Pin setup for HC-SR04
Two GPIO pins are defined for the HC-SR04 sensor:
TRIGis an output pin to trigger the ultrasonic pulse, andECHOis an input pin to receive the reflected pulse.TRIG = machine.Pin(17, machine.Pin.OUT) ECHO = machine.Pin(16, machine.Pin.IN)
Distance measurement function
The
distancefunction triggers the ultrasonic pulse and calculates the distance based on the time taken for the echo to return. It uses time-based functions to measure the duration of the echo.For more details, please refer to the working principle of the ultrasonic sensor module.
def distance(): TRIG.low() time.sleep_us(2) TRIG.high() time.sleep_us(10) TRIG.low() while not ECHO.value(): pass time1 = time.ticks_us() while ECHO.value(): pass time2 = time.ticks_us() during = time.ticks_diff(time2, time1) return during * 340 / 2 / 10000
Main loop
The main loop continuously calls the
distancefunction and prints the measured distance. It waits for 300 milliseconds between each measurement to prevent sensor saturation.while True: dis = distance() print("Distance: %.2f cm" % dis) time.sleep_ms(300)
