Lesson 09: Joystick Module
In this lesson, you’ll learn how to interface with and read data from a joystick module using the Raspberry Pi Pico W. You’ll explore initializing and reading analog values from the X and Y axes of the joystick, as well as handling digital input from its switch using MicroPython. This lesson is ideal for beginners, offering practical experience in reading and interpreting analog and digital inputs on the Raspberry Pi Pico W.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
Joystick Module
../_images/Lesson_09_Jostick_Module_bb.png
import machine  # Import hardware control module
import time  # Import time module
# Initialize X and Y axes of the joystick
x_joystick = machine.ADC(27)
y_joystick = machine.ADC(26)
# Initialize joystick switch with pull-up resistor
z_switch = machine.Pin(22, machine.Pin.IN, machine.Pin.PULL_UP)
while True:  # Continuous reading loop
    x_value = x_joystick.read_u16()  # Read X-axis value
    y_value = y_joystick.read_u16()  # Read Y-axis value
    z_value = z_switch.value()  # Read switch state
    # Print joystick values and switch state
    print("X: ", x_value, " Y: ", y_value)
    print("SW: ", z_value)
    time.sleep_ms(200)  # Loop every 200 milliseconds
Code Analysis
  1. Import Libraries
    The machine and time modules are imported for hardware control and time functions.
  2. Initialize Joystick Axes
    The joystick’s X and Y axes are connected to analog pins (27 and 26 respectively). These pins are initialized as ADC (Analog to Digital Converter) objects.
  3. Initialize Joystick Switch
    The joystick’s switch is connected to pin 22. It’s set as an input with a pull-up resistor. When the button is not pressed, it reads high (1), and when pressed, it reads low (0).
  4. Main Loop
    • An infinite loop continuously reads values from the joystick.
    • read_u16 method is used to read 16-bit values from the X and Y axes.
    • value() method is used to read the state of the switch.
    • The values are then printed, and the loop pauses for 200 milliseconds.
