Lesson 19: Temperature and Humidity Sensor Module (DHT11)
In this lesson, you’ll learn how to use the Raspberry Pi Pico W to connect with a DHT11 temperature and humidity sensor. You’ll explore accurate measurement of environmental conditions by recording temperature and humidity data. This tutorial offers practical guidance on using digital sensors with the Raspberry Pi Pico W, programming with MicroPython, and managing real-time data processing.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
The kit may contain different versions of the DHT11 module. Please confirm the wiring method according to the module you have.
module |
diagram |
import dht
import machine
# Initialize DHT11 sensor on GPIO 16
d = dht.DHT11(machine.Pin(16))
# Continuously read and print temperature and humidity
d.measure()
print("Temperature:" ,d.temperature()) # Print temperature
print("Humidity:" ,d.humidity()) # Print humidity
time.sleep_ms(1000) # Read every second
Code Analysis
Importing Libraries:
The code begins by importing necessary libraries.
dhtis for the DHT11 sensor,machineis for interacting with the hardware, andtimeis for adding delays in the loop.import dht import machine import time
Initializing the DHT11 Sensor:
The DHT11 sensor is initialized by specifying its connected GPIO pin. Here, it’s connected to GPIO 16 on the Raspberry Pi Pico W. This is done using the
machine.Pinfunction.d = dht.DHT11(machine.Pin(16))
Reading and Printing Data in a Loop:
The
while Trueloop enables the program to continuously read temperature and humidity data. Inside the loop,d.measure()is called to take a new measurement.d.temperature()andd.humidity()are used to retrieve the temperature and humidity data, respectively. These values are then printed. The loop pauses for one second (1000milliseconds) usingtime.sleep_ms(1000), ensuring the data is read and printed every second.while True: d.measure() print("Temperature:" ,d.temperature()) # Print temperature print("Humidity:" ,d.humidity()) # Print humidity time.sleep_ms(1000) # Read every second
