Lesson 13: Potentiometer Module
In this lesson, you’ll learn how to use a potentiometer with the Raspberry Pi Pico W to measure analog values. The potentiometer, which is a variable resistor, lets you adjust the voltage that the Raspberry Pi Pico W reads on one of its analog input pins. By turning the knob of the potentiometer, you’ll observe changes in the input value. This project offers a basic grasp of analog inputs and their application in electronic projects, making it an ideal entry point for beginners in electronics and MicroPython programming.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
../_images/Lesson_13_potentiometer_module_bb.png
import machine  # Hardware control library
import time  # Time control library
potentiometer = machine.ADC(26)  # Initialize ADC on pin 26
    value = potentiometer.read_u16()  # Read analog value
    print(value)  # Print the value
    time.sleep_ms(200)  # Delay of 200 ms between reads
Code Analysis
  1. Import Libraries
    First, the necessary libraries are imported. machine is for hardware control, and time is for managing delays.
  2. Initialize ADC (Analog to Digital Converter)
    The photoresistor is connected to pin 26 of the Pico W. This pin is initialized as an ADC pin to read analog values.
  3. Reading and Printing the Analog Value The code enters an infinite loop (while True:) where it continually reads the analog value from the photoresistor using potentiometer.read_u16() and prints it.
  4. Adding a Delay
    To prevent the loop from running too fast, a delay of 200 milliseconds is introduced using time.sleep_ms(200). This gives a readable output and reduces processor load.
