Lesson 28: RGB LED Module
In this lesson, you’ll learn how to control an RGB LED using the Raspberry Pi Pico W. You’ll discover how to set up PWM (Pulse Width Modulation) on different GPIO pins for each color channel of the RGB LED, allowing you to create various colors by adjusting the intensity of red, green, and blue components. This project offers beginners a great opportunity to gain practical experience with PWM and color mixing on Raspberry Pi Pico W using MicroPython. Additionally, you’ll learn how to handle interrupts to safely turn off the LED. This lesson provides a fun and interactive way to explore the basics of electronics and programming.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
RGB LED Module
../_images/Lesson_28_RGB_LED_Module_pico_bb.png
from machine import Pin, PWM
from time import sleep
# Initialize PWM for each color channel of an RGB LED
red = PWM(Pin(26))  # Red channel on GPIO pin 26
green = PWM(Pin(27))  # Green channel on GPIO pin 27
blue = PWM(Pin(28))  # Blue channel on GPIO pin 28
# Set 1000 Hz frequency for all channels
red.freq(1000)
green.freq(1000)
blue.freq(1000)
# Function to set RGB LED color
def set_color(r, g, b):
    red.duty_u16(r)  # Red intensity
    green.duty_u16(g)  # Green intensity
    blue.duty_u16(b)  # Blue intensity
        set_color(65535, 0, 0)  # Red
        sleep(1)
        set_color(0, 65535, 0)  # Green
        sleep(1)
        set_color(0, 0, 65535)  # Blue
        sleep(1)
    set_color(0, 0, 0)  # Turn off RGB LED on interrupt
Code Analysis
  1. Importing Libraries
    The machine module is imported to use the PWM class and Pin class. The time module is imported to use the sleep function for creating delays.
  2. Initializing PWM for RGB LED
    The RGB LED has three channels (Red, Green, Blue), each controlled by a separate PWM signal. The PWM signals are connected to GPIO pins 26, 27, and 28.
  3. Setting Frequency for PWM Signals
    The frequency of the PWM signals is set to 1000 Hz for all three channels.
    red.freq(1000)
    green.freq(1000)
    blue.freq(1000)
  4. Defining the set_color Function
    This function sets the color of the RGB LED. The duty_u16 method is used to set the duty cycle for each color channel, which determines the intensity of that color.
        red.duty_u16(r)
        green.duty_u16(g)
        blue.duty_u16(b)
  5. Main Program Loop
    An infinite loop is used to change the color of the LED. The set_color function is called with different values to display red, green, and blue colors. Each color is displayed for 1 second.
            sleep(1)
            sleep(1)
            sleep(1)
