Lesson 17: Rotary Encoder Moduleď
In this lesson, youâll learn how to use the Raspberry Pi Pico W to control a rotary encoder. The rotary encoder is an advanced sensor that translates knob rotation into an output signal, indicating both the amount and direction of rotation. This project offers hands-on experience with digital input devices, enhancing your ability to work with more complex sensors. Youâll configure the rotary encoder using specific GPIO pins, read its output to determine rotation direction and amount, and master using a button to trigger events.
Required Componentsď
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
Wiringď
Codeď
Open the
17_rotary_encoder_module.pyfile under the path ofuniversal-maker-sensor-kit-main/pico/Lesson_17_Rotary_Encoder_Moduleor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it. For detailed tutorials, please refer to Open and Run Code Directly.Here you need to use the
rotary_irq_rp2.py, please check if it has been uploaded to Pico W, for a detailed tutorial refer to Upload the Libraries to Pico.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
from rotary_irq_rp2 import RotaryIRQ
from machine import Pin
# Set GPIO 20 as an input pin for reading the button(sw)'s state
button_pin = Pin(20, Pin.IN, Pin.PULL_UP)
# Initialize the rotary encoder with specific GPIO pins and settings
rotary_encoder = RotaryIRQ(
pin_num_clk=18,
pin_num_dt=19,
min_val=0,
max_val=14,
reverse=False,
range_mode=RotaryIRQ.RANGE_WRAP,
# Store the initial value of the rotary encoder and button state
last_rotary_value = rotary_encoder.value()
last_button_state = button_pin.value()
# Main loop
# Read the current value of the rotary encoder and button state
current_rotary_value = rotary_encoder.value()
current_button_state = button_pin.value()
# Check if the rotary encoder's value has changed
if last_rotary_value != current_rotary_value:
last_rotary_value = current_rotary_value
print("result =", current_rotary_value)
# Check if the button's state changed from not pressed to pressed
if last_button_state and not current_button_state:
print("Button pressed!")
# Update the previous state of the button for the next loop iteration
last_button_state = current_button_state
# Short delay to prevent debouncing issues
time.sleep_ms(50)
Code Analysisď
Importing Libraries
First, the necessary libraries are imported.
rotary_irq_rp2is for the rotary encoder,timefor delays, andmachinefor hardware control.For more information about the
rotary_irq_rp2library, please visit MikeTeachman/micropython-rotary.from rotary_irq_rp2 import RotaryIRQ import time from machine import Pin
Setting up the Button Pin
The GPIO pin connected to the SW pin is configured as an input with a pull-up resistor. This ensures a stable HIGH signal when the button is not pressed.
Initializing the Rotary Encoder
The encoder is set up with specified GPIO pins for CLK and DT.
min_valandmax_valdefine the range of values, andrange_modesets how the value behaves at limits (wraps around in this case).rotary_encoder = RotaryIRQ( pin_num_clk=18, pin_num_dt=19, min_val=0, max_val=14, reverse=False, range_mode=RotaryIRQ.RANGE_WRAP, )
Storing Initial Values
The initial values of the rotary encoder and the button are stored to detect changes in their states later.
last_rotary_value = rotary_encoder.value() last_button_state = button_pin.value()
Main Loop
The loop continuously checks for changes in the rotary encoder value and button state. If the rotary value changes, it prints the new value. If the button state changes from unpressed to pressed, it prints âButton pressed!â.
while True: current_rotary_value = rotary_encoder.value() current_button_state = button_pin.value() if last_rotary_value != current_rotary_value: last_rotary_value = current_rotary_value print("result =", current_rotary_value) if last_button_state and not current_button_state: print("Button pressed!") last_button_state = current_button_state time.sleep_ms(50)
The
time.sleep_ms(50)at the end of the loop is to prevent debouncing issues, which can cause erratic readings.
