Lesson 24: Vibration Sensor Module (SW-420)
In this lesson, you will learn to connect and use a SW-420 Vibration Sensor Module with a Raspberry Pi Pico W. The course guides you through setting up the vibration sensor on GPIO 16 and writing a MicroPython script to monitor vibrations. You will write a loop to continually check the sensor’s output, displaying a message when vibrations are detected. This practical exercise introduces you to working with external sensors on the Raspberry Pi Pico W, enhancing your understanding of hardware interfacing and programming in MicroPython.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
../_images/Lesson_24_vibration_module_bb.png
from machine import Pin
# Initialize GPIO 16 as an input pin for the vibration sensor
vibration_sensor = Pin(16, Pin.IN)
# Continuously check the vibration sensor's state
    # If the sensor detects vibration (value is 1), print a message
    if vibration_sensor.value() == 1:
        print("Vibration detected!")
    # If no vibration is detected, print ellipses
        print("...")
    # Pause for 0.1 seconds to lower the demand on the CPU
    time.sleep(0.1)
Code Analysis
  1. Importing Required Libraries
    This imports the machine module for hardware related operations and time module for handling time-related tasks.
  2. Initializing the Vibration Sensor
    Here, GPIO 16 is set up as an input pin. The Pin class from the machine module is used to interact with the GPIO pins. Pin.IN configures it as an input.
  3. Continuous Sensor Monitoring
    A while True loop is used to create an endless loop for continuously checking the sensor’s state.
  4. Checking Sensor State and Responding
        print("...")
    Within the loop, vibration_sensor.value() checks the current state of the sensor. If it returns 1, it indicates vibration is detected, and a message is printed. Otherwise, ellipses are printed.
  5. Managing CPU Usage
    time.sleep(0.1)
    time.sleep(0.1) pauses the loop for 0.1 seconds. This is important to prevent the script from consuming too much CPU time.
