Lesson 08: IR Obstacle Avoidance Sensor Module
In this lesson, you’ll learn how to use the Raspberry Pi Pico W with an IR Obstacle Avoidance Sensor Module. We’ll walk you through setting up the sensor and writing a MicroPython script that continuously reads its value to detect obstacles. By monitoring changes in the sensor data, you’ll grasp how to use it for basic obstacle detection.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
from machine import Pin
# Initialize obstacle avoidance sensor connected to pin 16 as input
obstacle_avoidance_sensor = Pin(16, Pin.IN)
# Read and print the value of the obstacle avoidance sensor
print(obstacle_avoidance_sensor.value())
# Wait for 0.1 seconds before the next read
time.sleep(0.1)
Code Analysis
Importing Libraries
The
machinemodule is imported to interact with the GPIO pins, and thetimemodule is used for adding delays.from machine import Pin import time
Setting Up the Sensor
The obstacle avoidance sensor is set up as an input device on GPIO pin 16. The
Pin.INparameter configures the pin as an input.obstacle_avoidance_sensor = Pin(16, Pin.IN)
Reading Sensor Data in a Loop
The
while True:loop continuously checks the sensor’s output. If the sensor detects an obstacle, it returns0, which is printed out. Thetime.sleep(0.1)adds a small delay to make the readings more manageable.while True: print(obstacle_avoidance_sensor.value()) time.sleep(0.1)
If the sensor is not working properly, adjust the IR transmitter and receiver to make them parallel. Additionally, you can adjust the detection range using the built-in potentiometer.
