Lesson 29: Traffic Light Module
In this lesson, you will learn to create a traffic light system using the Raspberry Pi Pico W. You’ll program the Pico W to control three LEDs – red, yellow, and green – mimicking a real traffic light. This project offers a practical introduction to using Pulse Width Modulation (PWM) for LED brightness control and basic control structures in MicroPython. It’s ideal for beginners looking to explore digital signal processing and gain confidence in coding on the Raspberry Pi Pico W platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
../_images/Lesson_29_Traffic_Light_Module_pico_bb.png
from machine import Pin, PWM
# Initialize pins for LEDs
red = PWM(Pin(26), freq=1000)  #  red LED
yellow = PWM(Pin(27), freq=1000)  #  yellow LED
green = PWM(Pin(28), freq=1000)  # green LED
# Function to set the brightness of an LED (0-100%)
def set_brightness(led, brightness):
    if brightness < 0 or brightness > 100:
        raise ValueError("Brightness should be between 0 and 100")
    led.duty_u16(int(brightness / 100 * 65535))
    # Example sequence
        # Green light for 5 seconds
        set_brightness(green, 100)
        time.sleep(5)
        set_brightness(green, 0)
        # Blink Yellow light
        set_brightness(yellow, 100)
        time.sleep(0.5)
        set_brightness(yellow, 0)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        # Red light for 5 seconds
        set_brightness(red, 100)
        time.sleep(5)
        set_brightness(red, 0)
    # Turn off RGB LED on interrupt
Code Analysis
  1. Importing Libraries
    The machine library is used for controlling hardware components, and time is used for creating delays.
  2. Initializing LED Pins
    Here, we initialize the pins connected to the LEDs. PWM is used to control the brightness of the LEDs.
  3. Defining the Set Brightness Function
    Due to the fact that the pins of Raspberry Pi Pico can only output a maximum voltage of 3.3V, the green LED will appear dim.
    This function sets the brightness of the LEDs. It takes two parameters: the LED and the desired brightness level (0-100%). The duty_u16 method is used to set the PWM duty cycle.
  4. Main Loop and Traffic Light Sequence
    The while True loop makes the code run continuously. It controls the sequence of the traffic light: green, yellow (blinking), and red.
            time.sleep(5)
  5. Handling Keyboard Interrupt
    The except KeyboardInterrupt block is used to handle a manual interruption (like Ctrl+C). It turns off all LEDs when the script is interrupted.
