Lesson 04: Gas Sensor Module (MQ-2)
In this lesson, you’ll learn how to use the Raspberry Pi Pico W to read data from a gas sensor module (MQ-2) using MicroPython. We’ll guide you through setting up an ADC on GPIO pin 26 to process analog signals from the MQ-2 sensor. You’ll gain practical experience in continuously monitoring and printing sensor data to understand the presence of gases in the environment.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
import machine
import utime
# Initialize an ADC object on GPIO pin 26.
# This is typically used for reading analog signals.
mq2_AO = machine.ADC(26)
# Continuously read and print sensor data.
value = mq2_AO.read_u16() # Read and convert analog value to 16-bit integer
print("AO:", value) # Print the analog value
utime.sleep_ms(200) # Wait for 200 milliseconds before the next read
Code Analysis
Importing Libraries:
The code begins by importing necessary libraries:
machinefor hardware interactions, andutimefor handling time-related tasks.import machine import utime
Initializing the MQ-2 Sensor:
An ADC object is created on GPIO pin 26 to read analog signals from the MQ-2 sensor. The MQ-2 sensor outputs an analog signal which varies with the concentration of gas in the air.
Reading Sensor Data in a Loop:
The main loop of the program continuously reads the analog value from the sensor. The
read_u16method is used to read the analog value and convert it to a 16-bit integer. This value is then printed out. The loop includes a delay (utime.sleep_ms(200)) to wait for 200 milliseconds before reading the sensor value again. This delay is crucial to prevent overwhelming the sensor and the microcontroller with rapid readings.Note
MQ2 is a heating-driven sensor that usually requires preheating before use. During the preheating period, the sensor typically reads high and gradually decreases until it stabilizes.
while True: value = mq2_AO.read_u16() # Read and convert analog value to 16-bit integer print("AO:", value) # Print the analog value utime.sleep_ms(200) # Wait for 200 milliseconds before the next read
