Lesson 16: Real Time Clock Module (DS1302)
In this lesson, you’ll learn how to use the Raspberry Pi Pico W to interact with a DS1302 Real-Time Clock module. We’ll start by setting up the DS1302 and connecting it to the Pico W using specific GPIO pins. You’ll also learn how to retrieve and set the current date and time on the DS1302. Additionally, we’ll explore continuously displaying the current datetime on your console, updating every half second.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
Open the
16_ds1302_module.pyfile under the path ofuniversal-maker-sensor-kit-main/pico/Lesson_16_DS1302_Moduleor copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it. For detailed tutorials, please refer to Open and Run Code Directly.Here you need to use the
ds1302.py, please check if it has been uploaded to Pico W, for a detailed tutorial refer to Upload the Libraries to Pico.Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
from machine import Pin
import ds1302
# Initialize DS1302 RTC with specific GPIO pins
ds = ds1302.DS1302(Pin(5), Pin(18), Pin(19)) # (clk, dio, cs)
# Get current datetime from DS1302
ds.date_time()
# Set DS1302 datetime to 2024-01-01 Monday 00:00:00
ds.date_time([2024, 1, 1, 1, 0, 0, 0]) # (year,month,day,weekday,hour,minute,second)
# Set seconds to 10
ds.second(10)
# Continuously display current datetime every half second
print(ds.date_time())
time.sleep(0.5)
Code Analysis
Import Libraries
This section imports necessary libraries:
machinefor GPIO control,ds1302for the RTC module, andtimefor implementing delays.For more detail about the
ds1302library, please refer tods1302.py.from machine import Pin import ds1302 import time
Initialize the DS1302 RTC
This code initializes the DS1302 module by defining which GPIO pins of the Raspberry Pi Pico W are connected to the clock (clk), data input/output (dio), and chip select (cs) pins of the DS1302.
Get Current DateTime
Retrieves the current date and time from the DS1302. The
date_time()method returns a list containing year, month, day, weekday, hour, minute, and second.ds.date_time()
Set DS1302 DateTime
Sets the DS1302’s date and time to January 1, 2024, at 00:00:00. The day of the week (Monday) is represented by 1.
Set Seconds
Sets the seconds value of the DS1302’s time to 10.
ds.second(10)
Display Current DateTime Continuously
This loop continuously displays the current date and time every half second. The
time.sleep(0.5)function creates a half-second delay between each iteration.while True: print(ds.date_time()) time.sleep(0.5)
