Lesson 15: Raindrop Detection Module
In this lesson, you’ll learn how to use the Raspberry Pi Pico W to detect raindrops using a raindrop sensor connected to pin 16. The script continuously monitors for any indication of raindrops and prints “Raindrop detected!” when one is detected; otherwise, it displays “Monitoring…” as it waits for raindrops. This session offers hands-on experience in handling digital inputs with the Raspberry Pi Pico W and understanding environmental sensing in MicroPython, making it ideal for beginners in electronics and programming.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
../_images/Lesson_15_raindrop_detection_module_bb.png
from machine import Pin
# Initialize raindrop sensor connected to pin 16 as input
raindrop_sensor = Pin(16, Pin.IN)
    # Check the Raindrop sensor value
    if raindrop_sensor.value() == 0:
        print("Raindrop detected!")  # Raindrop detected
        print("Monitoring...")  # No raindrop detected
    time.sleep(0.1)  # Short delay of 0.1 seconds to reduce CPU usage
Code Analysis
  1. Initializing the Raindrop Sensor:
    The raindrop sensor is initialized using the Pin class from the machine module, set to pin 16 in input mode. This allows the Raspberry Pi Pico W to read the sensor output.
  2. Continuous Monitoring Loop:
    A continuous while loop is used to monitor the sensor. Inside the loop, the sensor value is checked. If the value is 0, it indicates raindrops are detected and prints “Raindrop detected!” Otherwise, it prints “Monitoring…” to indicate the absence of raindrops.
  3. Introducing a Delay:
    To reduce CPU usage, a delay of 0.1 seconds is introduced in each iteration of the loop using time.sleep(0.1). This prevents the loop from executing too rapidly.
    time.sleep(0.1)
