Lesson 30: Relay Module
In this lesson, you will learn how to use the Raspberry Pi Pico W to control a relay module. We will set up a basic circuit connecting the relay to the Pi and write a MicroPython script to toggle the relay on and off at one-second intervals. This project introduces you to controlling external devices such as relays and demonstrates practical output operations using the GPIO pins on the Raspberry Pi Pico W. Ideal for those interested in delving into home automation or managing other high-power devices, this lesson offers fundamental insight into how microcontrollers can interact with and control external hardware.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
from machine import Pin
# Replace this number with the GPIO pin number your relay is connected to
relay_pin = Pin(16, Pin.OUT)
def relay_on():
relay_pin.value(1) # Set relay to ON state
def relay_off():
relay_pin.value(0) # Set relay to OFF state
relay_on()
print("on....")
time.sleep(1) # Wait for 1 second
relay_off()
print("off....")
except:
relay_off() # Ensure the relay is turned off in case of an exception
print("Program interrupted, relay turned off.")
Code Analysis
Importing Libraries
The
machineandtimelibraries are imported to interact with GPIO pins and handle time-related functions, respectively.from machine import Pin import time
Initializing Relay Pin
A GPIO pin is set up as an output pin to control the relay. The
relay_pinvariable represents the GPIO pin connected to the relay.relay_pin = Pin(16, Pin.OUT)
Defining Relay Control Functions
Two functions,
relay_onandrelay_off, are defined to turn the relay on and off, respectively. These functions change the GPIO pin’s value to high (1) or low (0).def relay_on(): relay_pin.value(1) # Set relay to ON state def relay_off(): relay_pin.value(0) # Set relay to OFF state
Main Loop and Exception Handling
A continuous loop is created using
while True. Inside this loop, the relay is turned on and off with a 1-second delay between each state. If an interruption occurs (like a keyboard interruption), the relay is turned off for safety, and a message is printed.try: while True: relay_on() print("on....") time.sleep(1) # Wait for 1 second relay_off() print("off....") time.sleep(1) # Wait for 1 second except: relay_off() # Ensure the relay is turned off in case of an exception print("Program interrupted, relay turned off.")
