Lesson 31: Centrifugal Pump
In this lesson, you will learn how to operate a centrifugal pump using the Raspberry Pi Pico W and an L9110 motor control board. We’ll guide you through the process of configuring two PWM (Pulse Width Modulation) pins to control the motor. You’ll set up the pump to run for 5 seconds and then turn off. This practical exercise offers a valuable opportunity to delve into motor control mechanisms and PWM signals, crucial in microcontroller programming.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
Centrifugal Pump
L9110 Motor Driver Module
../_images/Lesson_31_Pump_pico_bb.png
from machine import Pin, PWM
pump_a = PWM(Pin(26), freq=1000)
pump_b = PWM(Pin(27), freq=1000)
# turn on pump
pump_a.duty_u16(0)
pump_b.duty_u16(65535)  # speed(0-65535)
time.sleep(5)
# turn off pump
pump_a.duty_u16(0)
pump_b.duty_u16(0)
Code Analysis
  1. Importing Libraries
    • The machine module is imported to interact with the GPIO pins and PWM functionalities of the Raspberry Pi Pico W.
    • The time module is used for creating delays in the code.
  2. Initializing PWM Objects
    • Two PWM objects, pump_a and pump_b, are created. They correspond to GPIO pins 26 and 27, respectively.
    • The frequency for PWM is set to 1000 Hz, a common frequency for motor control.
  3. Turning on the Pump
    • pump_a.duty_u16(0) sets the duty cycle of pump_a pin to 0, while pump_b.duty_u16(65535) sets the duty cycle of pump_b pin to 65535, running the motor at full speed. For more details, please refer to the working principle of L9110.
    • The pump runs for 5 seconds, controlled by time.sleep(5).
    # turn on pump
    pump_a.duty_u16(0)
    time.sleep(5)
  4. Turning off the Pump
    Both pump_a and pump_b are set to a duty cycle of 0, stopping the motor.
    # turn off pump
    pump_a.duty_u16(0)
    pump_b.duty_u16(0)
