Lesson 20: Temperature, Humidity & Pressure Sensor (BMP280)
In this lesson, you’ll learn how to connect the BMP280 temperature, humidity, and pressure sensor to the Raspberry Pi Pico W using MicroPython. You’ll get practical experience in setting up I2C communication, configuring the BMP280 sensor for weather monitoring, and obtaining temperature and pressure data. By the end of this tutorial, you’ll be able to view real-time environmental data on your console.
Required Components
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi Pico W
Wiring
../_images/Lesson_20_bmp280_bb.png
Code
  • Open the 20_bmp280_module.py file under the path of universal-maker-sensor-kit-main/pico/Lesson_20_BMP280_Module or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it. For detailed tutorials, please refer to Open and Run Code Directly.
  • Here you need to use the bmp280.py, please check if it has been uploaded to Pico W, for a detailed tutorial refer to Upload the Libraries to Pico.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
from machine import I2C, Pin
import bmp280
# Initialize I2C communication
i2c = I2C(0, sda=Pin(20), scl=Pin(21), freq=100000)
# Configure BMP280 sensor
bmp = bmp280.BMP280(i2c)
bmp.oversample(bmp280.BMP280_OS_HIGH)
    # Set sensor to weather monitoring mode
    bmp.use_case(bmp280.BMP280_CASE_WEATHER)
    # Print temperature and pressure data
    print("tempC: {}".format(bmp.temperature))
    print("pressure: {}Pa".format(bmp.pressure))
    # Read data every second
    time.sleep_ms(1000)
Code Analysis
  1. Importing Libraries and Initializing I2C Communication:
    This code segment imports necessary libraries and initializes I2C communication. The machine module is used to interact with the hardware components like I2C and pins. The bmp280 library is imported to interact with the BMP280 sensor.
    For more information about the bmp280 library, please visit dafvid/micropython-bmp280.
    import bmp280
  2. Configuring the BMP280 Sensor:
    Here, the BMP280 sensor is configured. An object bmp is created to interact with the sensor. The oversampling setting is adjusted for higher accuracy.
  3. Reading and Displaying Sensor Data in a Loop:
    The sensor is continuously read in an infinite loop. Each iteration sets the sensor to weather monitoring mode, reads the temperature and pressure, and prints them. The time.sleep_ms(1000) ensures the loop runs once every second.
        time.sleep_ms(1000)
