Lesson 12: PIR Motion Module (HC-SR501)
In this lesson, you’ll learn how to connect a PIR Motion Sensor to the Raspberry Pi Pico W. You’ll discover how to configure the sensor for motion detection and use basic MicroPython code to react to movement. By monitoring the PIR sensor, you’ll gain experience in managing digital inputs and creating a simple security measure or automation trigger.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
from machine import Pin
# Initialize PIR sensor connected to pin 16 as input
pir_sensor = Pin(16, Pin.IN)
# Check the PIR sensor value
if pir_sensor.value() == 0:
print("Monitoring...") # No motion detected
print("Somebody here!") # Motion detected
time.sleep(0.1) # Short delay of 0.1 seconds to reduce CPU usage
Code Analysis
Importing modules
The
machinemodule is imported to use thePinclass for GPIO pin control. Thetimemodule is imported for creating delays in the loop.from machine import Pin import time
Initializing the PIR sensor
The PIR sensor is connected to GPIO pin 16 of the Raspberry Pi Pico W. It is set as an input device because it sends data to the microcontroller.
# Initialize PIR sensor connected to pin 16 as input pir_sensor = Pin(16, Pin.IN)
Main loop
The
while Trueloop makes the code run continuously. Inside this loop, the PIR sensor’s value is checked. If the value is0, it means no motion is detected. Otherwise, motion is detected. A delay of 0.1 seconds is added to reduce CPU usage and prevent the code from running too fast.while True: # Check the PIR sensor value if pir_sensor.value() == 0: print("Monitoring...") # No motion detected else: print("Somebody here!") # Motion detected time.sleep(0.1) # Short delay of 0.1 seconds to reduce CPU usage
