Lesson 25: Water Level Sensor Module
In this lesson, you will learn how to use the Raspberry Pi Pico W to measure water levels with a water level sensor. You’ll understand how to connect the sensor to the board, read its analog output using MicroPython, and interpret these readings to determine water levels. This practical session is aimed at developing your skills in sensor integration and data acquisition with the Raspberry Pi Pico W.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
import machine
import utime
# Initialize an ADC object on GPIO pin 26.
# This is typically used for reading analog signals.
water_level_sensor = machine.ADC(26)
# Continuously read and print sensor data.
value = water_level_sensor.read_u16() # Read and convert analog value to 16-bit integer
print("AO:", value) # Print the analog value
utime.sleep_ms(200) # Wait for 200 milliseconds before the next read
Code Analysis
Importing Libraries
Here, we import necessary libraries:
machinefor hardware interactions andutimefor time-based functions.import machine import utime
Initializing the Water Level Sensor
An ADC object is created on GPIO pin 26 to read analog signals from the water level sensor. ADC is crucial for converting the sensor’s analog signals to digital format that the microcontroller can process.
# Initialize an ADC object on GPIO pin 26. water_level_sensor = machine.ADC(26)
Reading and Printing Sensor Data
The
while Trueloop enables continuous reading of the sensor data.read_u16method converts the analog signal to a 16-bit integer. The value is printed, and the loop pauses for 200 milliseconds usingutime.sleep_ms(200)to prevent rapid firing.while True: value = water_level_sensor.read_u16() # Read and convert analog value to 16-bit integer print("AO:", value) # Print the analog value utime.sleep_ms(200) # Wait for 200 milliseconds before the next read
