Time of Flight Micro-LIDAR Distance Sensor (VL53L0X)
The VL53L0X module is an advanced time-of-flight (ToF) ranging sensor that offers highly accurate distance measurement, regardless of the target’s color and reflectance. Manufactured by STMicroelectronics, this sensor excels in measuring absolute distances up to 2 meters, making it well-suited for various applications in fields such as robotics, drones, and wearable devices.
Specification
Supply Voltage: 3.3V or 5V
PCB Size: 11 x 25mm
Communication method: I2C
ToF ranging length: ≤2M
Pinout
VIN: This is the power pin.
GND: Common ground for power and logic.
SCL: I2C clock pin, connect to your microcontrollers I2C clock line.
SDA: I2C data pin, connect to your microcontrollers I2C data line.
GPIO1: Programmable interrupt output. This output is not level-shifted.
XSHUT: This pin is an active-low shutdown input; Driving this pin low puts the sensor into hardware standby. This input is not level-shifted.
Example
Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X) (Arduino UNO)
Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X) (ESP32)
Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X) (Raspberry Pi Pico)
Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X) (Raspberry Pi)
