Traffic light
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to build a simple traffic light system using the ESP32, a TM1637 4-digit display, and LED.
The display counts down each light phase—red, yellow, and green—just like a real traffic signal.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
4-Digit Segment Display Module |
Traffic Light LED |
Common Connections:
Traffic light LED
R: Connect to GPIO25 on the ESP32.
Y: Connect to GPIO26 on the ESP32.
G: Connect to GPIO27 on the ESP32.
CLK: Connect to GPIO23 on the ESP32.
DIO: Connect to GPIO22 on the ESP32.
Writing the Code
To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// ------- TM1637 pins (ESP32 GPIOs) -------
#define CLK_PIN 23 // TM1637 CLK -> GPIO23
#define DIO_PIN 22 // TM1637 DIO -> GPIO22
// ------- Traffic light pins (ESP32 GPIOs) -------
const int redPin = 25; // Red LED
const int yellowPin = 26; // Yellow LED
const int greenPin = 27; // Green LED
// Create display object
TM1637Display display(CLK_PIN, DIO_PIN);
// Setup traffic light pins
pinMode(redPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(greenPin, OUTPUT);
// Initialize display
display.setBrightness(7); // 0 (dim) to 7 (bright)
display.clear();
// Red light phase - 10s
digitalWrite(redPin, HIGH);
digitalWrite(yellowPin, LOW);
digitalWrite(greenPin, LOW);
countdown(10);
// Yellow light phase - 3s
digitalWrite(redPin, LOW);
digitalWrite(yellowPin, HIGH);
countdown(3);
// Green light phase - 10s
digitalWrite(greenPin, HIGH);
countdown(10);
// Countdown function using TM1637 display
void countdown(int seconds) {
for (int i = seconds; i > 0; i--) {
// Show in rightmost 2 digits (positions 2 & 3)
display.showNumberDec(i, true, 2, 2);
delay(1000);
display.clear();
