Gas Leak Monitor
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
This project simulates a basic gas leak detection system using an MQ-2 gas sensor, a red LED, and a buzzer.
The sensor continuously monitors gas concentration. If the reading exceeds a set threshold, the buzzer sounds and the LED blinks to indicate danger.
Otherwise, the system remains silent and the LED stays off.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
Buzzer Modudle |
LED |
7 |
MQ-2 Gas Sensor Module |
8 |
220Ω resistor |
Common Connections:
A0: Connect to GPIO34 on the ESP32.
Buzzer Modudle
I/O: Connect to GPIO18 on the ESP32.
LED
Connect the LED anode to GPIO19 on the ESP32, and the cathode to a 220Ω resistor , then to the negative power bus on the breadboard.
Writing the Code
Don’t forget to select the board(ESP32 Dev Module) and the correct port before clicking the Upload button.
Board: ESP32 Dev Module (or similar)
Components: MQ-2 gas sensor (analog), red LED, buzzer
Purpose: Simulate gas leak detection.
Logic:
- If gas concentration > threshold: buzzer sounds, red LED blinks.
- Otherwise: buzzer is off, red LED is off.
const int sensorPin = 34; // MQ-2 analog output (ESP32 ADC pin)
const int buzzerPin = 18; // Buzzer pin (GPIO 18)
const int redLEDPin = 19; // Red LED pin (GPIO 19)
int sensorValue = 0; // Variable to store sensor value
// On ESP32, analogRead() returns 0–4095 (12-bit).
// Original threshold 90 (on 0–1023) ≈ 360 on 0–4095.
const int threshold = 720; // Gas detection threshold (tune as needed)
Serial.begin(115200); // Initialize serial monitor (higher baud for ESP32)
pinMode(buzzerPin, OUTPUT); // Set buzzer pin as output
pinMode(redLEDPin, OUTPUT); // Set red LED pin as output
digitalWrite(buzzerPin, LOW);
digitalWrite(redLEDPin, LOW);
// Read sensor value (0–4095 on ESP32 ADC)
sensorValue = analogRead(sensorPin);
Serial.print("Analog output: ");
Serial.println(sensorValue);
if (sensorValue > threshold) {
// Gas above threshold: buzzer ON, LED blinking
tone(buzzerPin, 500); // 500 Hz tone on buzzer
digitalWrite(redLEDPin, HIGH); // LED ON
delay(250);
digitalWrite(redLEDPin, LOW); // LED OFF
delay(250); // Total blink period = 500 ms
} else {
// Gas below threshold: buzzer OFF, LED OFF
noTone(buzzerPin); // Stop buzzer
delay(50);
