Color Memory
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use four LCDs, four buttons, and a passive buzzer with the ESP32 to create a color memory game.
At the start of the game, an LED lights up at random. The player must press the corresponding button to proceed. A wrong input ends the game.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
Passive Buzzer |
Button |
7 |
LED |
8 |
220Ω resistor |
Common Connections:
LEDS
Blue: Connect the LED anode to GPIO19 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Green: Connect the LED anode to GPIO18 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Yellow: Connect the LED anode to GPIO17**on the ESP32 , and the **cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Red: Connect the LED anode to GPIO16 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Passive Buzzer
+: Connect to GPIO27 on the ESP32.
-: Connect to breadboard’s negative power bus.
Buttons
Blue Button: Connect to the Blue LED’s cathode on the breadboard, and the other end to GPIO26 on the ESP32 board.
Green Butto: Connect to the Green LED’s cathode on the breadboard, and the other end to GPIO25 on the ESP32 board.
Yellow Butto: Connect to the Yellow LED’s cathode on the breadboard, and the other end to GPIO33 on the ESP32 board.
Red Butto: Connect to the Red LED’s cathode on the breadboard, and the other end to GPIO32 on the ESP32 board.
Writing the Code
You can copy this code into Arduino IDE. * To install the library, use the Arduino Library Manager and search for esp_system and install it.
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
#include <esp_system.h> // for esp_random()
// ===== LED and button pin definitions (ESP32 safe GPIOs) =====
// Avoid flash pins (6–11) and strapping pins (0/2/12/15) for reliability.
const int redLED = 16;
const int yellowLED = 17;
const int greenLED = 18;
const int blueLED = 19;
const int redButton = 32; // has internal pull-up
const int yellowButton = 33; // has internal pull-up
const int greenButton = 25; // has internal pull-up
const int blueButton = 26; // has internal pull-up
const int buzzer = 27; // works with tone() on ESP32
// ===== Game state =====
int sequence[100]; // Generated color sequence
int playerInput[100]; // Player-entered sequence
int level = 0; // Current level (1..)
bool gameOver = false; // Game over flag
void startGame();
void playSequence();
bool getPlayerInput();
void endGame();
void lightUpLED(int color);
// LED outputs
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(blueLED, OUTPUT);
// Buttons as inputs with internal pull-ups (wire the other side to GND)
pinMode(redButton, INPUT_PULLUP);
pinMode(yellowButton, INPUT_PULLUP);
pinMode(greenButton, INPUT_PULLUP);
pinMode(blueButton, INPUT_PULLUP);
// Buzzer output
pinMode(buzzer, OUTPUT);
Serial.begin(115200);
// Seed RNG from ESP32 hardware random generator
randomSeed((uint32_t)esp_random());
// Start the game
startGame();
if (!gameOver) {
// Play current sequence and then check player's input
playSequence();
if (!getPlayerInput()) {
endGame();
} else {
delay(500); // brief pause before next level
} else {
// Restart after a short delay
delay(1500);
startGame();
void startGame() {
level = 1;
gameOver = false;
// Power-on cue: all LEDs on + short beep
digitalWrite(redLED, HIGH);
digitalWrite(yellowLED, HIGH);
digitalWrite(greenLED, HIGH);
digitalWrite(blueLED, HIGH);
tone(buzzer, 1000, 500);
delay(500);
// All off
digitalWrite(redLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(greenLED, LOW);
digitalWrite(blueLED, LOW);
delay(300);
void playSequence() {
// Append one random color (1..4) to the sequence for this level
sequence[level - 1] = random(1, 5);
// Play the sequence up to current level
for (int i = 0; i < level; i++) {
lightUpLED(sequence[i]);
delay(300);
bool getPlayerInput() {
bool inputReceived = false;
// Wait until any button is pressed (active LOW)
while (!inputReceived) {
if (digitalRead(redButton) == LOW) {
playerInput[i] = 1;
lightUpLED(1);
inputReceived = true;
} else if (digitalRead(yellowButton) == LOW) {
playerInput[i] = 2;
lightUpLED(2);
} else if (digitalRead(greenButton) == LOW) {
playerInput[i] = 3;
lightUpLED(3);
} else if (digitalRead(blueButton) == LOW) {
playerInput[i] = 4;
lightUpLED(4);
// simple debounce
delay(5);
// Verify input against the sequence
if (playerInput[i] != sequence[i]) {
return false; // mismatch -> fail
// Wait for button release before next input
while (digitalRead(redButton) == LOW ||
digitalRead(yellowButton)== LOW ||
digitalRead(greenButton) == LOW ||
delay(5);
delay(200);
// Advance to next level after a full correct round
level++;
return true;
void endGame() {
gameOver = true;
// Flash all LEDs and beep to indicate game over
for (int i = 0; i < 5; i++) {
tone(buzzer, 1000, 300);
delay(200);
delay(200);
void lightUpLED(int color) {
// Light a specific LED and play a tone depending on color
switch (color) {
case 1: // Red
tone(buzzer, 500, 300);
break;
case 2: // Yellow
tone(buzzer, 600, 300);
break;
case 3: // Green
tone(buzzer, 700, 300);
break;
case 4: // Blue
tone(buzzer, 800, 300);
break;
delay(300);
// Turn all LEDs off
