Joystick LED
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you will learn how to use ESP32 along with Joystick Module, LEDs, and resistors to create a light play.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Several |
LED |
Several |
Joystick Module |
Common Connections:
LED
Blue: Connect the LED anode to GPIO19 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Green: Connect the LED anode to GPIO18 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Yellow: Connect the LED anode to GPIO17**on the ESP32 , and the **cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Red: Connect the LED anode to GPIO16 on the ESP32, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Joystick Module
VRY: Connect to GPIO35 on the ESP32.
VRX: Connect to GPIO34 on the ESP32.
Writing the Code
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
// ===== LED pin definitions (ESP32 safe GPIOs) =====
// Avoid strapping pins like 0/2/12/15 for reliability.
// You can change these if they clash with other hardware.
const int redLED = 16; // negative X (LEFT)
const int yellowLED = 17; // negative Y (DOWN)
const int greenLED = 18; // positive X (RIGHT)
const int blueLED = 19; // positive Y (UP)
// ===== Joystick analog inputs (ESP32 ADC1, input-only) =====
// Most joystick modules output 0–3.3V when powered from 3.3V.
// GPIO34/35 are input-only and support analogRead on ADC1.
const int xPin = 34; // VRX -> GPIO34 (ADC1)
const int yPin = 35; // VRY -> GPIO35 (ADC1)
// ===== Analog range and dead zone (ESP32 is 12-bit: 0..4095) =====
const int MID_VAL = 2048; // midpoint for 12-bit ADC
const int DEAD_ZONE = 300; // adjust as needed
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(blueLED, OUTPUT);
// Initialize all LEDs OFF
digitalWrite(redLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(greenLED, LOW);
digitalWrite(blueLED, LOW);
Serial.begin(115200);
// Read joystick (ESP32 returns 0..4095 by default)
int xVal = analogRead(xPin);
int yVal = analogRead(yPin);
Serial.print("X: "); Serial.print(xVal);
Serial.print(" Y: "); Serial.println(yVal);
// Turn all LEDs OFF before deciding direction
// Invert both axes: swap sign of offsets
// (Original: dx = xVal - MID_VAL; dy = yVal - MID_VAL;)
int dx = MID_VAL - xVal; // inverted X
int dy = MID_VAL - yVal; // inverted Y
// If inside dead zone, light nothing
if (abs(dx) < DEAD_ZONE && abs(dy) < DEAD_ZONE) {
// Do nothing
} else {
// Pick the axis with the larger magnitude
if (abs(dx) > abs(dy)) {
// X dominates
if (dx > 0) {
// +X (after inversion) -> RIGHT
digitalWrite(greenLED, HIGH);
} else {
// -X (after inversion) -> LEFT
digitalWrite(redLED, HIGH);
} else {
// Y dominates
if (dy > 0) {
// +Y (after inversion) -> UP
digitalWrite(blueLED, HIGH);
} else {
// -Y (after inversion) -> DOWN
digitalWrite(yellowLED, HIGH);
delay(100);
