Radar Guard 2.0
Kit purchase
../_images/esp32_kit.png
Includes ESP32 board
PURCHASE LINK
ESP32 Ultimate Starter Kit
ESP32 WROOM 32E +
Universal Maker Sensor Kit
Course Introduction
In this lesson, we will learn how to use the Ultrasonic Sensor Module, Digital Servo Motor, and I2C LCD 1602 with the ESP32 Board to create a radar defense system version 2.0.
When the ultrasonic sensor module is running, it emits an audible alarm and flashes the red LED if it detects an obstacle within its sensing range. If no obstacle is detected, indicating a safe state, the green LED stays on.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
ESP-WROOM-32 ESP32 ESP-32S Development Board
USB Type-C cable
Wires
Several
1kΩ resistor
LED
I2C LCD 1602
Digital Servo Motor
Passive Buzzer
../_images/Radar_Guard_2.0_bb1.png
Common Connections:
  • LED
    • Green: Connect the LEDs anode to a 1kΩ resistor then to the GPIO17 on ESP32, and the LEDs cathode to negative power bus on the breadboard.
    • Red: Connect the LEDs anode to a 1kΩ resistor then to the GPIO16 on ESP32, and the LEDs cathode to negative power bus on the breadboard.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to GPIO27 on the ESP32.
  • Passive Buzzer
    • +: Connect to GPIO4 on the ESP32.
    • -: Connect to breadboard’s negative power bus.
  • I2C LCD 1602
    • SDA: Connect to GPIO21 on the ESP32.
    • SCL: Connect to GPIO22 on the ESP32.
  • Ultrasonic Sensor Module
    • Trig: Connect to GPIO26 on the ESP32.
    • Echo: Connect to GPIO25 on the ESP32.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and ESP32Servo and install it.
  • Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
#include <Arduino.h>
#include <Wire.h>
#include <ESP32Servo.h>
// --- Pins ---
const int trigPin  = 26;
const int echoPin  = 25;
const int servoPin = 27;
const int redLed   = 16;
const int greenLed = 17;
const int buzzer   = 4;    // Passive buzzer
LiquidCrystal_I2C lcd(0x27, 16, 2);
// --- Config ---
const int alertDistance = 30;
const unsigned long updateInterval = 20;
const int triggerThreshold = 2;
const unsigned long displayDuration = 500;
const unsigned long blinkInterval   = 200;
Servo radarServo;
int currentAngle = 0;
int increment    = 1;
unsigned long lastServoUpdate = 0;
bool displayAlarm = false;
bool alarmActive  = false;
int  triggerCount = 0;
int  detectedAngle = 0;
unsigned long displayStartTime = 0;
unsigned long lastBlinkTime    = 0;
bool blinkState = false;
const int BUZZ_CH = 0;
static inline void buzzerOn(uint32_t freqHz) {
#if defined(ESP_ARDUINO_VERSION_MAJOR) && (ESP_ARDUINO_VERSION_MAJOR >= 3)
  ledcWriteTone(buzzer, freqHz);    //
#else
  ledcWriteTone(BUZZ_CH, freqHz);   //
#endif
static inline void buzzerOff() {
  ledcWriteTone(buzzer, 0);
#else
  ledcWriteTone(BUZZ_CH, 0);
#endif
void lcdSetEmpty();
void startAlarmDisplay();
void alarmBlink();
void exitAlarm();
float getDistance();
  Wire.begin(21, 22);
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcdSetEmpty();
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  radarServo.attach(servoPin);
  radarServo.write(currentAngle);
  ledcAttach(buzzer, /*freq*/1000, /*resolution bits*/10);
#else
  ledcSetup(BUZZ_CH, /*freq*/1000, /*resolution bits*/10);
  ledcAttachPin(buzzer, BUZZ_CH);
#endif
  digitalWrite(greenLed, HIGH);
  unsigned long now = millis();
  if (now - lastServoUpdate >= updateInterval) {
    lastServoUpdate = now;
    if (currentAngle % 5 == 0) {
      float d = getDistance();
      if (!displayAlarm && !alarmActive) {
        triggerCount = (d < alertDistance) ? (triggerCount + 1) : 0;
        if (triggerCount >= triggerThreshold) {
          triggerCount = 0;
          detectedAngle = currentAngle;
      } else if (alarmActive && d >= alertDistance) {
        exitAlarm();
    currentAngle += increment;
    if (currentAngle >= 180) { currentAngle = 180; increment = -1; }
    else if (currentAngle <= 0) { currentAngle = 0; increment = 1; }
  if (displayAlarm) {
    if (now - displayStartTime >= displayDuration) {
      alarmActive   = true;
      lastBlinkTime = now;
  } else if (alarmActive) {
    alarmBlink();
void startAlarmDisplay() {
  displayAlarm     = true;
  displayStartTime = millis();
  digitalWrite(greenLed, LOW);
  digitalWrite(redLed, LOW);
  buzzerOff();
  lcd.clear();
  char buf[8];
  snprintf(buf, sizeof(buf), "%d", detectedAngle);
  int len1 = strlen(buf) + 1;
  int start1 = (16 - len1) / 2;
  lcd.setCursor(start1, 0);
  lcd.print(buf);
  lcd.write(223); // '°'
  const char* msg = "Foreign Body";
  int len2 = strlen(msg);
  int start2 = (16 - len2) / 2;
  lcd.setCursor(start2, 1);
  lcd.print(msg);
void alarmBlink() {
  if (now - lastBlinkTime >= blinkInterval) {
    blinkState = !blinkState;
    digitalWrite(redLed, blinkState);
    if (blinkState) buzzerOn(1000); else buzzerOff();
void exitAlarm() {
  triggerCount = 0;
  buzzerOff();
  lcdSetEmpty();
void lcdSetEmpty() {
  lcd.clear();
  lcd.setCursor(1, 0);
  lcd.print("Area is Empty");
float getDistance() {
  digitalWrite(trigPin, LOW);  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH); delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH, 30000);
  return duration * 0.034f / 2.0f;
