Morse Code
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use a button, an LED, and a buzzer with the ESP32 to create a simple Morse code trainer.
By pressing the button for short or long durations, you can input dots and dashes. The LED and buzzer provide immediate feedback, and the serial monitor displays whether you sent a dot (·) or a dash (—). This project is great for learning Morse code basics interactively.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
Active Buzzer |
Button |
7 |
LED |
8 |
1kΩ resistor |
Common Connections:
LED
Connect the LED to a 1kΩ resistor, then to anode to GPIO26 on the ESP32, and the cathode to the negative power bus on the breadboard.
Passive Buzzer
+: Connect to 25 on the ESP32.
-: Connect to breadboard’s negative power bus.
Button
Connect to the breadboard’s negative power bus, and the other end to GPIO27 on the ESP32 board.
Writing the Code
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
// ===== ESP32-Compatible Morse Code Trainer =====
// NOTE:
// - Uses internal pull-up on the button (active LOW).
// - Active buzzer is driven by GPIO HIGH/LOW (no PWM needed).
// - Avoid ESP32 strapping pins and input-only pins.
#include <Arduino.h>
// ---------- Pin Definitions (ESP32 safe GPIOs) ----------
const int BUTTON_PIN = 27; // Push button to GND (has internal pull-up)
const int BUZZER_PIN = 25; // Active buzzer (+) to GPIO, (-) to GND
const int LED_PIN = 26; // LED anode via 220Ω resistor to GPIO
// ---------- Timing Constants (milliseconds) ----------
const int DOT_DURATION = 200; // Standard dot duration
const int DASH_DURATION = 600; // Standard dash duration
const int DEBOUNCE_DELAY = 50; // Button debounce time
// ---------- Global State ----------
bool lastButtonState = HIGH; // Previous sampled button state
unsigned long pressStartTime = 0; // Timestamp when button was pressed
void activateFeedback(); // Turn ON LED and buzzer
void deactivateFeedback(); // Turn OFF LED and buzzer
void handleMorseSymbol(); // Decide dot vs dash after release
// Use a higher baud on ESP32 for snappier logs
Serial.begin(115200);
while (!Serial) { /* wait on native USB boards; harmless on ESP32 */ }
// Configure I/O
pinMode(BUTTON_PIN, INPUT_PULLUP); // Internal pull-up, active LOW
pinMode(LED_PIN, OUTPUT);
pinMode(BUZZER_PIN, OUTPUT);
// Ensure outputs start OFF
digitalWrite(LED_PIN, LOW);
digitalWrite(BUZZER_PIN, LOW);
Serial.println("Morse Code Trainer Ready (ESP32)");
Serial.println("Short press: Dot (·) Long press: Dash (—)");
// Read current button state (LOW when pressed)
int currentButtonState = digitalRead(BUTTON_PIN);
// Detect press edge: HIGH -> LOW
if (currentButtonState == LOW && lastButtonState == HIGH) {
delay(DEBOUNCE_DELAY); // Debounce guard
if (digitalRead(BUTTON_PIN) == LOW) {
pressStartTime = millis(); // Mark press start time
activateFeedback(); // Visual + audio ON
Serial.println("Button PRESSED");
// Detect release edge: LOW -> HIGH
if (currentButtonState == HIGH && lastButtonState == LOW) {
if (digitalRead(BUTTON_PIN) == HIGH) {
deactivateFeedback(); // Turn feedback OFF immediately
handleMorseSymbol(); // Classify the symbol
// Update last state for next loop
lastButtonState = currentButtonState;
// Turn ON both visual and audio feedback
void activateFeedback() {
digitalWrite(LED_PIN, HIGH);
digitalWrite(BUZZER_PIN, HIGH); // Active buzzer: HIGH = sound
// Turn OFF both feedback channels
void deactivateFeedback() {
// Decide dot or dash based on press duration
void handleMorseSymbol() {
unsigned long pressDuration = millis() - pressStartTime;
if (pressDuration < DASH_DURATION) {
Serial.println("Sent: DOT (·)");
// Enforce minimum dot duration so the tempo feels consistent
if (pressDuration < DOT_DURATION) {
delay(DOT_DURATION - pressDuration);
} else {
Serial.println("Sent: DASH (—)");
// Enforce minimum dash duration
delay(DASH_DURATION - pressDuration);
