Speed Detection
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
This project functions as a basic speed detection system using two infrared (IR) sensors and an LCD display.
When a vehicle passes the front sensor, the system starts a timer; it stops the timer once the vehicle triggers the back sensor.
Using the known distance between the sensors, the system calculates the vehicle’s speed and displays it in km/h on a 16x2 I2C LCD.
If the speed exceeds a set threshold (e.g., 60 km/h), a buzzer alerts for overspeeding. The LCD resets after each detection cycle, ready for the next vehicle.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Type-C cable |
Breadboard |
Wires |
Several |
I2C LCD 1602 |
IR Obstacle Avoidance Sensor Module |
7 |
Passive Buzzer |
Common Connections:
Passive Buzzer
+: Connect to GPIO25 on the ESP32.
-: Connect to breadboard’s negative power bus.
I2C LCD 1602
SDA: Connect to GPIO21 on the ESP32.
SCL: Connect to GPIO22 on the ESP32.
VCC: Connect to breadboard’s 5V red power bus.
IR Obstacle Avoidance Sensor Module Front
OUT: Connect to GPIO32 on the Arduino.
VCC: Connect to breadboard’s 3.3V red power bus.
IR Obstacle Avoidance Sensor Module Back
OUT: Connect to GPIO33 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
#include <Wire.h>
// Use I2C address 0x27, 16x2 LCD
LiquidCrystal_I2C lcd(0x27, 16, 2);
// ---- Pin map (ESP32 DevKit v1 safe choices) ----
// IR sensors (digital, active LOW)
const int irFront = 32; // Front IR sensor input (GPIO32)
const int irBack = 33; // Back IR sensor input (GPIO33)
// Active buzzer (driven HIGH to beep)
const int buzzer = 25; // Buzzer output (GPIO25)
// Distance between the two sensors in meters
float distanceMeters = 1.30;
// Timing
unsigned long t1 = 0, t2 = 0;
bool carDetected = false;
// ESP32 I2C pins: SDA=21, SCL=22 (set bus here before using lcd)
Wire.begin(21, 22);
// Inputs/outputs
pinMode(irFront, INPUT); // Use INPUT unless your sensor needs pull-ups
pinMode(irBack, INPUT);
pinMode(buzzer, OUTPUT);
digitalWrite(buzzer, LOW);
// LCD init
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("No car detected");
// Wait for a car to pass the front sensor (active LOW)
if (!carDetected && digitalRead(irFront) == LOW) {
carDetected = true;
t1 = millis();
lcd.clear();
lcd.print("Searching...");
// Wait until back sensor is triggered, with timeout safeguard
const unsigned long waitTimeoutMs = 5000; // 5 s failsafe
unsigned long startWait = millis();
while (digitalRead(irBack) == HIGH) {
if (millis() - startWait > waitTimeoutMs) {
// Timeout: reset state and notify
lcd.clear();
lcd.print("Back sensor TO");
delay(1500);
lcd.clear();
return;
delay(1);
t2 = millis();
// Compute speed
unsigned long deltaT = t2 - t1; // ms
float timeSec = deltaT / 1000.0f; // s
float speedKmh = (distanceMeters / timeSec) * 3.6f;
lcd.clear();
lcd.print("Speed: ");
lcd.print((int)speedKmh);
lcd.print(" km/h");
lcd.setCursor(0, 1);
if (speedKmh <= 60.0f) {
lcd.print("Normal Speed");
} else {
lcd.print("Over Speeding");
digitalWrite(buzzer, HIGH);
delay(1000);
delay(3000);
lcd.clear();
