Smart Stop 1.0
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use an L9110 Motor Driver Module, an Ultrasonic Sensor Module, and a TT motor with the ESP32 to create a Smart Stop 1.0 system.
As the obstacle gets closer to the Ultrasonic Sensor Module, the TT motor gradually slows down until it comes to a stop.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
ESP-WROOM-32 ESP32 ESP-32S Development Board |
USB Cable |
Breadboard |
Wires |
Several |
L9110 Motor Driver Module |
Ultrasonic Sensor Module |
7 |
TT Motor |
Common Connections:
Trig: Connect to GPIO17 on the ESP32.
Echo: Connect to GPIO16 on the ESP32.
VCC: Connect to breadboard’s 5V red power bus.
TT Motor
Connect to MOTOR B on the L9110 Motor Driver Module.
B-1B: Connect to GPIO26 on the ESP32.
B-1A: Connect to GPIO25 on the ESP32.
Writing the Code
Don’t forget to select the board(ESP32 Dev module) and the correct port before clicking the Upload button.
#include <Arduino.h>
// ---- Pin mapping for ESP32 ----
// Ultrasonic sensor (HC-SR04)
const int trigPin = 17; // TRIG (3.3V OK)
const int echoPin = 16; // ECHO -> must be divided to ~3.3V on ESP32
// L9110 motor driver (B channel)
const int motorB_1A = 25; // L9110 B-IA / IN1B
const int motorB_2A = 26; // L9110 B-IB / IN2B
Serial.begin(9600); // Serial monitor
// Ultrasonic I/O
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// Motor outputs
pinMode(motorB_1A, OUTPUT);
pinMode(motorB_2A, OUTPUT);
// Ensure motor is stopped at startup
analogWrite(motorB_1A, 0);
analogWrite(motorB_2A, 0);
float distance = readSensorData(); // Read distance (cm)
Serial.print("Distance: ");
Serial.print(distance, 2);
Serial.println(" cm");
controlMotor(distance); // Drive motor based on distance
delay(100); // Small delay to reduce noise
// Read distance from HC-SR04 (returns centimeters)
float readSensorData() {
// Send 10 µs trigger pulse
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Measure echo pulse width with timeout (30 ms)
unsigned long duration = pulseIn(echoPin, HIGH, 30000UL);
if (duration == 0) return 9999.0f; // Timeout -> treat as very far
// Convert to centimeters (duration/58 is a common shortcut)
return duration / 58.0f;
// Control DC motor via L9110 (forward on B-IA, B-IB kept low)
void controlMotor(float distance) {
if (distance < 5) {
// Stop
} else if (distance < 8) {
// Slow
analogWrite(motorB_1A, 85);
} else if (distance < 11) {
// Medium
analogWrite(motorB_1A, 170);
} else if (distance > 14) {
// Max
analogWrite(motorB_1A, 255);
} else {
// 11–14 cm -> stop (matches original implicit behavior)
