Speed Dial
  • 🎁 Looking for parts? Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Kit purchase
../_images/esp32_kit.png
Includes ESP32 board
PURCHASE LINK
ESP32 Ultimate Starter Kit
ESP32 WROOM 32E +
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll use a potentiometer and a DC motor with the ESP32 to create a simple motor speed control system.
By rotating the potentiometer, you can adjust the motor speed from stop to full speed. The ESP32 reads the potentiometer value, maps it to PWM output, and drives the motor in one direction with variable speed.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
ESP-WROOM-32 ESP32 ESP-32S Development Board
USB Cable
Wires
Several
TA6586 - Motor Driver Chip
Potentiometer Sensor Module
TT Motor
Power Supply
../_images/Speed_Dial_bb1.png
Common Connections:
  • Potentiometer Sensor Module
    • OUT: Connect to GPIO34 on the ESP32.
  • TA6586 - Motor Driver Chip
    • BI: Connect to GPIO19 on the ESP32.
    • FI: Connect to GPIO18 on the ESP32.
  • TT Motor
    • Connect to B0, F0 on the TA6586 - Motor Driver Chip.
Writing the Code
  • Don’t forget to select the board(ESP32 Dev Module) and the correct port before clicking the Upload button.
// Potentiometer and motor control for ESP32 using analogWrite()
const int potPin    = 34;  // Potentiometer signal pin (ESP32 ADC input)
const int motorPin1 = 18;  // Motor PWM pin
const int motorPin2 = 19;  // Motor direction pin
  // Motor pins as output
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  // Potentiometer pin as input
  pinMode(potPin, INPUT);
  // Set initial motor state
  digitalWrite(motorPin1, LOW);
  digitalWrite(motorPin2, LOW);
  // Read analog value from potentiometer (0–4095 on ESP32)
  int val = analogRead(potPin);
  // Map value to PWM range (0–255)
  int speed = map(val, 0, 4095, 0, 255);
  // Set direction (LOW = one direction)
  // Drive motor with mapped speed
  analogWrite(motorPin1, speed);
  delay(10);  // Small delay for stability
