4.1.17 GAME– Guess Number
Guessing Numbers is a fun party game where you and your friends take turns inputting a number (0~99). The range will be smaller with the inputting of the number till a player answers the riddle correctly. Then the player is defeated and punished. For example, if the lucky number is 51 which the players cannot see, and the player ① inputs 50, the prompt of number range changes to 50~99; if the player ② inputs 70, the range of number can be 50~70; if the player ③ inputs 51, this player is the unlucky one. Here, we use keypad to input numbers and use LCD to output outcomes.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
GPIO25 |
Pin 22 |
25 |
SPIMOSI |
Pin 19 |
12 |
10 |
GPIO22 |
Pin 15 |
22 |
GPIO27 |
Pin 13 |
27 |
GPIO17 |
Pin 11 |
0 |
17 |
SDA1 |
Pin 3 |
SDA1(8) |
SDA1(2) |
SCL1 |
Pin 5 |
SCL1(9) |
SDA1(3) |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Setup I2C (see I²C Configuration.)
Step 3: Change directory.
cd ~/raphael-kit/python/
Step 4: Run.
sudo python3 4.1.17_GAME_GuessNumber.py
After the program runs, there displays the initial page on the LCD:
Welcome!
Press A to go!
Press ‘A’, and the game will start and the game page will appear on the LCD.
Enter number:
0 ‹point‹ 99
A random number ‘point’ is produced but not displayed on the LCD when the game starts, and what you need to do is to guess it. The number you have typed appears at the end of the first line till the final calculation is finished. (Press ‘D’ to start the comparation, and if the input number is larger than 10, the automatic comparation will start.)
The number range of ‘point’ is displayed on the second line. And you must type the number within the range. When you type a number, the range narrows; if you got the lucky number luckily or unluckily, there will appear “You’ve got it!”
If you get the error
FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.If you get
ModuleNotFoundError: No module named 'smbus2'error, please runsudo apt install python3-smbus2.If the error
OSError: [Errno 121] Remote I/O errorappears, it means the module is miswired or the module is broken.If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import LCD1602
import random
##################### HERE IS THE KEYPAD LIBRARY TRANSPLANTED FROM Arduino ############
#class Key:Define some of the properties of Key
class Keypad():
def __init__(self, rowsPins, colsPins, keys):
self.rowsPins = rowsPins
self.colsPins = colsPins
self.keys = keys
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
def read(self):
pressed_keys = []
for i, row in enumerate(self.rowsPins):
GPIO.output(row, GPIO.HIGH)
for j, col in enumerate(self.colsPins):
index = i * len(self.colsPins) + j
if (GPIO.input(col) == 1):
GPIO.output(row, GPIO.LOW)
return pressed_keys
################ EXAMPLE CODE START HERE ################
count = 0
pointValue = 0
upper=99
lower=0
def setup():
global keypad, last_key_pressed,keys
rowsPins = [18,23,24,25]
colsPins = [10,22,27,17]
keys = ["1","2","3","A",
"4","5","6","B",
"7","8","9","C",
"*","0","#","D"]
keypad = Keypad(rowsPins, colsPins, keys)
last_key_pressed = []
LCD1602.init(0x27, 1) # init(slave address, background light)
LCD1602.clear()
LCD1602.write(0, 0, 'Welcome!')
LCD1602.write(0, 1, 'Press A to Start!')
def init_new_value():
global pointValue,upper,count,lower
pointValue = random.randint(0,99)
upper = 99
lower = 0
count = 0
print('point is %d' %(pointValue))
def detect_point():
global count,upper,lower
if count > pointValue:
if count < upper:
upper = count
elif count < pointValue:
if count > lower:
lower = count
elif count == pointValue:
count = 0
return 1
count = 0
return 0
def lcd_show_input(result):
LCD1602.clear()
if result == 1:
LCD1602.write(0,1,'You have got it!')
time.sleep(5)
init_new_value()
lcd_show_input(0)
return
LCD1602.write(0,0,'Enter number:')
LCD1602.write(13,0,str(count))
LCD1602.write(0,1,str(lower))
LCD1602.write(3,1,' < Point < ')
LCD1602.write(13,1,str(upper))
def loop():
global keypad, last_key_pressed,count
while(True):
result = 0
pressed_keys = keypad.read()
if len(pressed_keys) != 0 and last_key_pressed != pressed_keys:
if pressed_keys == ["A"]:
init_new_value()
lcd_show_input(0)
elif pressed_keys == ["D"]:
result = detect_point()
elif pressed_keys[0] in keys:
if pressed_keys[0] in list(["A","B","C","D","#","*"]):
continue
count = count * 10
count += int(pressed_keys[0])
if count >= 10:
print(pressed_keys)
time.sleep(0.1)
# Define a destroy function for clean up everything after the script finished
def destroy():
# Release resource
GPIO.cleanup()
LCD1602.clear()
setup()
loop()
destroy()
Code Explanation
At the beginning part of the code are the functional functions of keypad and I2C LCD1602. You can learning more details about them in 1.1.7 I2C LCD1602 and 2.1.8 Keypad.
Here, what we need to know is as follows:
upper = 99
lower = 0
count = 0
The function produces the random number ‘point’ and resets the range hint of the point.
def detect_point():
if count < upper:
upper = count
if count > lower:
lower = count
count = 0
return 1
count = 0
return 0
detect_point() compares the input number (count) with the produced
“point”. If the comparing outcome is that they are not same,
count will assign values to upper and lower and return
‘0’; otherwise, if the outcome indicates they are same, there
returns ‘1’.
LCD1602.clear()
if result == 1:
time.sleep(5)
init_new_value()
lcd_show_input(0)
return
This function works for displaying the game page.
str(count): Because write() can only support the data type —
string, str() is needed to convert the number into
string.
def loop():
while(True):
result = 0
init_new_value()
lcd_show_input(0)
continue
count = count * 10
if count >= 10:
print(pressed_keys)
time.sleep(0.1)
main() contains the whole process of the program, as show below:
Initialize I2C LCD1602 and Keypad.
Judge whether the button is pressed and get the button reading.
If the button ‘A’ is pressed, a random number 0-99 will appear then the game starts.
If the button ‘D’ is detected to have been pressed, the program will enter into the outcome judgement.
If the button 0-9 is pressed, the value of count will be changed; if the count is larger than 10, then the judgement starts.
The changes of the game and its values are displayed on LCD1602.
Phenomenon Picture
