4.1.5 Intelligent Visual Doorbell
In this project, let’s make a DIY intelligent visual doorbell.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
GPIO27 |
Pin 13 |
27 |
Experimental Procedures
Step 1: Build the circuit.
Before this project, you need to make sure you complete 3.1.3 Audio Module & 3.1.2 Video Module.
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
python3 4.1.5_DoorBell.py
After the code runs:
The program waits for the doorbell button to be pressed.
When pressed, a doorbell sound plays and a 5-second video is recorded.
The video is saved as
visitor.mp4in the user’s home directory.The system then returns to standby until the next button press.
Press
Ctrl+Cto exit and clean up resources.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import os
import RPi.GPIO as GPIO
from pygame import mixer
from picamera2.encoders import H264Encoder
from picamera2.outputs import FfmpegOutput
# USER DIRECTORY
user = os.getlogin()
user_home = os.path.expanduser(f"~{user}")
# CAMERA SETUP (Picamera2)
camera = Picamera2()
# Create a video configuration WITHOUT the deprecated "video=" argument
video_config = camera.create_video_configuration(
main={"size": (1280, 720), "format": "XBGR8888"}
camera.configure(video_config)
# Create H264 encoder (10 Mbps is good quality for doorbell)
encoder = H264Encoder(bitrate=10_000_000)
# GPIO SETUP
BtnPin = 18
status = False
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(BtnPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
mixer.init()
def button_pressed(pin):
"""Button callback"""
global status
status = True
# MAIN LOOP
def main():
global status
GPIO.add_event_detect(BtnPin, GPIO.FALLING,
callback=button_pressed, bouncetime=250)
print("Doorbell system running... Press the button to record.")
if status:
print("Visitor detected!")
# Play doorbell sound
mixer.music.load(f"{user_home}/raphael-kit/music/doorbell.wav")
mixer.music.set_volume(0.7)
mixer.music.play()
# Use QTGL preview
camera.start_preview(Preview.QTGL)
# Output file
output_path = f"{user_home}/visitor.mp4"
output = FfmpegOutput(output_path)
# Start recording
camera.start_recording(encoder, output)
print(f"Recording video to {output_path}")
time.sleep(5) # Record for 5 seconds
# Stop everything
mixer.music.stop()
camera.stop_recording()
camera.stop_preview()
print("Recording finished.\n")
status = False
time.sleep(0.05)
# CLEAN EXIT
def destroy():
print("\nExiting...")
mixer.quit()
GPIO.cleanup()
camera.close()
print("Program exited cleanly.")
if __name__ == "__main__":
setup()
main()
destroy()
Code Explanation
Retrieves the current user’s home directory to store the recorded video.
user = os.getlogin() user_home = os.path.expanduser(f"~{user}")
Creates a Picamera2 instance and configures it for video recording.
camera = Picamera2() video_config = camera.create_video_configuration( main={"size": (1280, 720), "format": "XBGR8888"} ) camera.configure(video_config)
Sets up the GPIO button on
GPIO18as an input with a pull-up resistor.GPIO.setmode(GPIO.BCM) GPIO.setup(BtnPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
Loads and initializes the audio mixer used to play the doorbell sound.
mixer.init()
Registers a callback that sets
statustoTruewhen the button is pressed.GPIO.add_event_detect(BtnPin, GPIO.FALLING, callback=button_pressed, bouncetime=250)
Plays the doorbell sound, starts the preview window, and begins video recording.
mixer.music.load(f"{user_home}/raphael-kit/music/doorbell.wav") mixer.music.play() camera.start_preview(Preview.QTGL) camera.start_recording(encoder, output)
Records a 5-second video and saves it as
visitor.mp4.time.sleep(5) camera.stop_recording() camera.stop_preview()
Cleans up all resources when the program is stopped with
Ctrl+C.mixer.quit() GPIO.cleanup() camera.close()
