2.1.8 Keypad
A keypad is a rectangular array of buttons. In this project, We will use it input characters.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Step 2: Open the code file.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 2.1.8_Keypad.py
After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
class Keypad():
def __init__(self, rowsPins, colsPins, keys):
self.rowsPins = rowsPins
self.colsPins = colsPins
self.keys = keys
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
def read(self):
pressed_keys = []
for i, row in enumerate(self.rowsPins):
GPIO.output(row, GPIO.HIGH)
for j, col in enumerate(self.colsPins):
index = i * len(self.colsPins) + j
if (GPIO.input(col) == 1):
GPIO.output(row, GPIO.LOW)
return pressed_keys
def setup():
global keypad, last_key_pressed
rowsPins = [18,23,24,25]
colsPins = [10,22,27,17]
keys = ["1","2","3","A",
"4","5","6","B",
"7","8","9","C",
"*","0","#","D"]
keypad = Keypad(rowsPins, colsPins, keys)
last_key_pressed = []
def loop():
pressed_keys = keypad.read()
if len(pressed_keys) != 0 and last_key_pressed != pressed_keys:
print(pressed_keys)
time.sleep(0.1)
# Define a destroy function for clean up everything after the script finished
def destroy():
# Release resource
GPIO.cleanup()
setup()
loop()
destroy()
Code Explanation
def setup():
"4","5","6","B",
"7","8","9","C",
"*","0","#","D"]
Declare each key of the matrix keyboard to the array keys[] and define the pins on each row and column.
def loop():
print(pressed_keys)
time.sleep(0.1)
This is the part of the main function that reads and prints the button value.
The function keyRead() will read the state of every button.
The statement if len(pressed_keys) != 0 and last_key_pressed !=
pressed_keys is used to judge
whether a key is pressed and the state of the pressed button. (If you press '3' when you press '1', the judgement is tenable.)
Prints the value of the currently pressed key when the condition is tenable.
The statement last_key_pressed = pressed_keys assigns the state of each
judgment to an array last_key_pressed to facilitate the next round of
conditional judgment.
def read(self):
pressed_keys = []
return pressed_keys
This function assigns a high level to each row in turn, and when the
button in the column is pressed, the column in which the key is located
gets a high level. After the two-layer loop is judged, the value of the
button whose state is 1 is stored in the array pressed_keys.
If you press the key ‘3’:
rowPins[0] is written in high level, and colPins[2] gets high level.
colPins[0]、colPins[1]、colPins[3] get low level.
There are four states: 0, 0, 1, 0; and we write '3' into pressed_keys.
When rowPins[1] , rowPins[2] , rowPins[3] are written into high level, colPins[0] ~ colPins[4] get low level.
The loop stopped, there returns pressed_keys = ‘3’.
If you press the buttons ‘1’ and ‘3’, there will return pressed_keys = [‘1’,’3’].
Phenomenon Picture
