4.1.2 Music Player
In project 3.1.3 Audio Module, let speaker play a song. Now we add 3 buttons to control the play/pause and volume of the music.
../_images/musicplayer_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Audio Module and Speaker
Button
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
../_images/3.1.16_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/3.1.16fritzing.png
After building the circuit according to the above diagram, then plug the audio cable into the Raspberry Pi’s 3.5mm audio jack.
../_images/audio41.png
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
python3 4.1.2_MusicPlayer.py
After the code runs, Raspberry Pi will play the my_music.mp3 file in the ~/raphael-kit/music directory.
  • Button 1 pauses/play the music.
  • Button 2 decreases the volume.
  • Button 3 increases the volume.
If you want to upload other music files to Raspberry Pi, you can refer to FileZilla Software.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
from pygame import mixer
import RPi.GPIO as GPIO
import os
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
BtnPin1 = 18
BtnPin2 = 17
BtnPin3 = 27
volume = 0.7
status = False
upPressed = False
downPressed = False
playPressed = False
def setup():
    mixer.init()
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(BtnPin1, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(BtnPin2, GPIO.IN, GPIO.PUD_UP)
    GPIO.setup(BtnPin3, GPIO.IN, GPIO.PUD_UP)
def clip(x,min,max):
    if x < min:
        return min
    elif x > max:
        return max
    return x
def play(pin):
    global playPressed
    playPressed = True
def volDown(pin):
    global downPressed
    downPressed = True
def volUp(pin):
    global upPressed
    upPressed = True
def main():
    global volume, status
    global downPressed, upPressed, playPressed
    mixer.music.load(f'{user_home}/raphael-kit/music/my_music.mp3')
    mixer.music.set_volume(volume)
    mixer.music.play()
    GPIO.add_event_detect(BtnPin1, GPIO.FALLING, callback=play)
    GPIO.add_event_detect(BtnPin2, GPIO.FALLING, callback=volDown)
    GPIO.add_event_detect(BtnPin3, GPIO.FALLING, callback=volUp)
        if upPressed:
            volume = volume + 0.1
            upPressed = False
        if downPressed:
            volume = volume - 0.1
            downPressed = False
        if playPressed:
            if status:
                mixer.music.pause()
                status = not status
                mixer.music.unpause()
                status = not status
            playPressed = False
            time.sleep(0.5)
        volume = clip(volume,0.2,1)
        time.sleep(0.1)
def destroy():
    # Release resource
    GPIO.cleanup()
    mixer.music.stop()
if __name__ == '__main__':
    setup()
        main()
    # When 'Ctrl+C' is pressed, the program
    # destroy() will be  executed.
        destroy()
Code Explanation
mixer.init()
Import the Mixer method in the pygame library and initialize the method.
BtnPin1 = 18
BtnPin2 = 17
BtnPin3 = 27
volume = 0.7
Define the pin ports of the three buttons and set the initial volume to 0.7.
upPressed = False
downPressed = False
playPressed = False
UpPressed, downPressed and playPressed are all interrupt flags, the corresponding task will be executed When they are True.
if x < min:
    return min
elif x > max:
    return max
return x
The clip() function is used to set the upper and lower limits of input parameters.
Set the key detection events of BtnPin1, BtnPin2 and BtnPin3.
  • When BtnPin1 is pressed, the interrupt function play() is executed.
  • when BtnPin2 is pressed, the interrupt function volDown() is executed.
  • When BtnPin3 is pressed, the interrupt function volUp() is executed.
Phenomenon Picture
../_images/4.1.2musicplayer.JPG
