4.1.14 Password Lock
In this project, we will use a keypad and a LCD to make a combination lock. The LCD will display a corresponding prompt for you to type your password on the Keypad. If the password is input correctly, “Correct” will be displayed.
On the basis of this project, we can add additional electronic components, such as buzzer, LED and so on, to add different experimental phenomena for password input.
../_images/list_Password_Lock.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
I2C LCD1602
Keypad
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
SDA1
Pin 3
SCL1
Pin 5
../_images/Schematic_three_one9.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image262.png
Step 2: Change directory.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 4.1.14_PasswordLock.py
After the code runs, keypad is used to input password: 1984. If the “CORRECT” appears on LCD1602, there is no wrong with the password; otherwise, “WRONG KEY” will appear.
  • If you get the error FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.
  • If you get ModuleNotFoundError: No module named 'smbus2' error, please run sudo apt install python3-smbus2.
  • If the error OSError: [Errno 121] Remote I/O error appears, it means the module is miswired or the module is broken.
  • If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import LCD1602
##################### HERE IS THE KEYPAD LIBRARY TRANSPLANTED FROM Arduino ############
#class Key:Define some of the properties of Key
class Keypad():
    def __init__(self, rowsPins, colsPins, keys):
        self.rowsPins = rowsPins
        self.colsPins = colsPins
        self.keys = keys
        GPIO.setwarnings(False)
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW)
        GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
    def read(self):
        pressed_keys = []
        for i, row in enumerate(self.rowsPins):
            GPIO.output(row, GPIO.HIGH)
            for j, col in enumerate(self.colsPins):
                index = i * len(self.colsPins) + j
                if (GPIO.input(col) == 1):
            GPIO.output(row, GPIO.LOW)
        return pressed_keys
################ EXAMPLE CODE START HERE ################
LENS = 4
password=['1','9','8','4']
testword=['0','0','0','0']
keyIndex=0
def check():
    for i in range(0,LENS):
        if(password[i]!=testword[i]):
            return 0
    return 1
def setup():
    global keypad, last_key_pressed
    rowsPins = [18,23,24,25]
    colsPins = [10,22,27,17]
    keys = ["1","2","3","A",
            "4","5","6","B",
            "7","8","9","C",
            "*","0","#","D"]
    keypad = Keypad(rowsPins, colsPins, keys)
    last_key_pressed = []
    LCD1602.init(0x27, 1)    # init(slave address, background light)
    LCD1602.clear()
    LCD1602.write(0, 0, 'WELCOME!')
    LCD1602.write(2, 1, 'Enter password')
    time.sleep(2)
def destroy():
    LCD1602.clear()
    GPIO.cleanup()
def loop():
    global keyIndex
    global LENS
    while(True):
        pressed_keys = keypad.read()
        if len(pressed_keys) != 0 and last_key_pressed != pressed_keys:
            LCD1602.clear()
            LCD1602.write(0, 0, "Enter password:")
            LCD1602.write(15-keyIndex,1, pressed_keys)
            testword[keyIndex]=pressed_keys
            keyIndex+=1
            if (keyIndex is LENS):
                if (check() is 0):
                    LCD1602.clear()
                    LCD1602.write(3, 0, "WRONG KEY!")
                    LCD1602.write(0, 1, "please try again")
                    LCD1602.clear()
                    LCD1602.write(4, 0, "CORRECT!")
                    LCD1602.write(2, 1, "welcome back")
            keyIndex=keyIndex%LENS
        time.sleep(0.1)
if __name__ == '__main__':     # Program start from here
        setup()
        loop()
    except KeyboardInterrupt:  # When 'Ctrl+C' is pressed, the program destroy() will be  executed.
        destroy()
Code Explanation
LENS = 4
        "4","5","6","B",
        "7","8","9","C",
        "*","0","#","D"]
Here, we define the length of the password LENS, the array keys that store the matrix keyboard keys, and the array password that stores the correct password.
class Keypad():
        self.keys = keys
This class is the code that reads the values of the pressed keys. Refer to 2.1.8 Keypad of this document for more details.
while(True):
            LCD1602.clear()
            keyIndex+=1
Read the key value and store it in the test array testword. If the number of stored key values is more than 4, the correctness of the password is automatically verified, and the verification results are displayed on the LCD interface.
def check():
            return 0
    return 1
Verify the correctness of the password. Return 1 if the password is entered correctly, and 0 if not.
Phenomenon Picture
../_images/image263.jpeg
