š Ready to explore and create with us? Click [here] and join today!
1.1.7 I2C LCD1602ļ
Introductionļ
LCD1602 is a character type liquid crystal display, which can display 32 (16*2) characters at the same time.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramļ
T-Board Name |
physical |
SDA1 |
Pin 3 |
SCL1 |
Pin 5 |
Experimental Proceduresļ
Step 1: Build the circuit.
Step 2: Setup I2C (see I²C Configuration. If you have set I2C, skip this step.)
Step 3: Change directory.
cd ~/raphael-kit/python/
Step 4: Run.
sudo python3 1.1.7_Lcd1602.py
After the code runs, you can see Greetings!, From SunFounder displaying on the LCD.
If you get the error
FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.If you get
ModuleNotFoundError: No module named 'smbus2'error, please runsudo apt install python3-smbus2.If the error
OSError: [Errno 121] Remote I/O errorappears, it means the module is miswired or the module is broken.If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import LCD1602
def setup():
LCD1602.init(0x27, 1) # init(slave address, background light)
LCD1602.write(0, 0, 'Greetings!')
LCD1602.write(1, 1, 'From SunFounder')
time.sleep(2)
def destroy():
LCD1602.clear()
if __name__ == "__main__":
setup()
finally:
destroy()
Code Explanation
import LCD1602
This file is an open source file for controlling I2C LCD1602. It allows us to easily use I2C LCD1602.
The function initializes the I2C system with the designated device symbol. The first parameter is the address of the I2C device, which can be detected through the i2cdetect command (see Appendix for details). The address of I2C LCD1602 is generally 0x27.
Within this function, āGreetings!! ā is the character to be printed on the Row 0+1, column 0+1 on LCD. Now you can see āGreetings!! From SunFounderā displayed on the LCD.
Phenomenon Pictureļ
