4.1.3 Speech Clock
In this project, let’s make a voice clock with a speaker and a 4-digit 7-segment display. The 4-digit 7-segment display will display the time, and the speaker will broadcast the time every hour.
../_images/3.1.17components.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Audio Module and Speaker
4-Digit 7-Segment Display
74HC595
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
../_images/4.1.3_speechclock_schematic.png ../_images/3.1.17_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/3.1.17fritzing.png
Before this project, you need to make sure you complete 3.1.4 Text-to-speech.
Step 2: Use the command date to view the local time.
date
If the local time is different from the real time, you need to use the following command to set the time zone.
sudo dpkg-reconfigure tzdata
Choose your time zone.
../_images/tzdata.png
Step 3: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
python3 4.1.3_SpeechClock.py
After the code runs:
  • A welcome message is spoken: “Clock system started. Welcome!”
  • The four-digit display shows the current time in HH:MM format.
  • At the start of each hour (minute = 0), the system announces the current time once.
  • The display updates continuously until Ctrl+C is pressed, after which GPIO resources are cleaned up.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
from tts import TTS
# Initialize TTS
tts = TTS(engine="espeak")
tts.lang('en-US')
# GPIO pins
SDI = 24
RCLK = 23
SRCLK = 25
placePin = (10, 22, 27, 17)
# Seven-segment encoding
def setup():
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(SDI, GPIO.OUT)
    GPIO.setup(RCLK, GPIO.OUT)
    GPIO.setup(SRCLK, GPIO.OUT)
    for pin in placePin:
        GPIO.setup(pin, GPIO.OUT)
def clearDisplay():
    for _ in range(8):
        GPIO.output(SDI, 1)
        GPIO.output(SRCLK, GPIO.HIGH)
        GPIO.output(SRCLK, GPIO.LOW)
    GPIO.output(RCLK, GPIO.HIGH)
    GPIO.output(RCLK, GPIO.LOW)
def hc595_shift(data):
    for i in range(8):
        GPIO.output(SDI, (0x80 & (data << i)))
def pickDigit(digit):
    # Turn all digits off
        GPIO.output(pin, GPIO.LOW)
    # Turn selected digit ON
    GPIO.output(placePin[digit], GPIO.HIGH)
def loop():
    status = 0
        now = time.localtime()
        hour = now.tm_hour
        minute = now.tm_min
        # Display minute (unit)
        clearDisplay()
        pickDigit(0)
        hc595_shift(number[minute % 10])
        # Display minute (tens)
        clearDisplay()
        pickDigit(1)
        hc595_shift(number[(minute // 10) % 10])
        # Display hour (unit)
        clearDisplay()
        pickDigit(2)
        hc595_shift(number[hour % 10])
        # Display hour (tens)
        clearDisplay()
        pickDigit(3)
        hc595_shift(number[(hour // 10) % 10])
        # Speak once every hour (at minute == 0)
        if minute == 0 and status == 0:
            tts.say(f'The time is now {hour} hours and {minute} minutes')
            time.sleep(3)   # Give time to finish speaking
            status = 1
        elif minute != 0:
            status = 0
        time.sleep(0.005)  # Prevent CPU overload
def destroy():
    GPIO.cleanup()
if __name__ == '__main__':
    setup()
    # ★ Welcome message at startup
    tts.say("Clock system started. Welcome!")
    time.sleep(3)
        loop()
        destroy()
Code Explanation
  1. Initializes the text-to-speech engine using espeak and sets the language to English.
    tts.lang('en-US')
  2. Defines the GPIO pins used for the shift register (74HC595) and the digit-select pins for the 4-digit display.
    SDI = 24
    RCLK = 23
    SRCLK = 25
  3. Stores the segment encoding values used to display digits 0–9 on the seven-segment display.
  4. Clears the display by shifting eight “1” bits into the shift register.
    def clearDisplay():
        for _ in range(8):
            GPIO.output(SDI, 1)
  5. Sends one byte of segment data to the 74HC595 to update the digit being displayed.
        for i in range(8):
  6. Selects one of the four digit positions (thousands, hundreds, tens, ones) for multiplexing.
  7. Reads the current time from the system clock.
    hour = now.tm_hour
    minute = now.tm_min
  8. Updates each digit on the seven-segment display to show the current time in HH:MM format.
  9. Speaks the current time once at the start of each hour using text-to-speech.
        status = 1
    elif minute != 0:
        status = 0
  10. Plays a welcome message when the program starts.
  11. Cleans up all GPIO pins when the user stops the program with Ctrl+C.
    GPIO.cleanup()
Phenomenon Picture
../_images/4.1.3speech_clock.JPG
