4.1.8 Battery Indicator(MCP3008)
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPICE0 |
Pin 24 |
10 |
8 |
SPIMOSI |
Pin 19 |
12 |
10 |
SPIMISO |
Pin 21 |
13 |
9 |
SPISCLK |
Pin 23 |
14 |
11 |
GPIO25 |
Pin 22 |
25 |
GPIO12 |
Pin 32 |
26 |
12 |
GPIO16 |
Pin 36 |
27 |
16 |
GPIO20 |
Pin 38 |
28 |
20 |
GPIO21 |
Pin 40 |
29 |
21 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
GPIO19 |
Pin 35 |
24 |
19 |
GPIO26 |
Pin 37 |
25 |
26 |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python
sudo python3 4.1.11-2_BatteryIndicator.py
After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# GPIO pins connected to 10 LEDs, ordered from left to right
led_pins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26] # BCM numbering
# GPIO setup
GPIO.setmode(GPIO.BCM)
for pin in led_pins:
GPIO.setup(pin, GPIO.OUT)
GPIO.output(pin, GPIO.LOW)
# Initialize SPI
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CE0
spi.max_speed_hz = 1000000 # 1 MHz
# Read value from MCP3008 channel
def read_adc(channel):
return -1
value = ((r[1] & 0x03) << 8) | r[2]
return value
# Light up LED bar graph according to value
def led_bar_graph(level):
for i, pin in enumerate(led_pins):
if i < level:
GPIO.output(pin, GPIO.HIGH)
# Main loop
analog_val = read_adc(0) # Read from MCP3008 channel 0
level = int(analog_val * 10 / 1023)
print(f"ADC: {analog_val}, Level: {level}")
time.sleep(0.2)
finally:
GPIO.cleanup()
spi.close()
Code Explanation
This program reads analog voltage from an MCP3008 ADC and displays the result on a 10-LED bar graph using a Raspberry Pi (BCM pin layout).
Import Modules
RPi.GPIOcontrols the GPIO pins on Raspberry Pi.spidevcommunicates with MCP3008 via SPI.timeprovides delay/sleep functionality.
#!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time
GPIO LED Setup
A list of 10 GPIO pins is defined for LED control. These pins are configured as output and initialized to LOW (off).
# GPIO pins connected to 10 LEDs, ordered from left to right led_pins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26] # BCM numbering GPIO.setmode(GPIO.BCM) for pin in led_pins: GPIO.setup(pin, GPIO.OUT) GPIO.output(pin, GPIO.LOW)
SPI Initialization
Initializes SPI bus 0 and chip enable 0 (CE0) to communicate with MCP3008. The communication speed is set to 1 MHz.
spi = spidev.SpiDev() spi.open(0, 0) # Bus 0, CE0 spi.max_speed_hz = 1000000 # 1 MHz
ADC Read Function
Reads an analog value from a specified MCP3008 channel (0–7). The function sends a 3-byte SPI command and decodes the 10-bit result.
def read_adc(channel): if channel < 0 or channel > 7: return -1 r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 0x03) << 8) | r[2] return value
LED Bar Graph Function
Lights up LEDs based on the analog level. If the level is 7, the first 7 LEDs will be ON and the rest OFF.
def led_bar_graph(level): for i, pin in enumerate(led_pins): if i < level: GPIO.output(pin, GPIO.HIGH) else: GPIO.output(pin, GPIO.LOW)
Main Loop
Continuously reads analog input from channel 0, scales the result to a value from 0 to 10, and updates the LED display accordingly. Prints ADC and level values for monitoring.
try: while True: analog_val = read_adc(0) level = int(analog_val * 10 / 1023) led_bar_graph(level) print(f"ADC: {analog_val}, Level: {level}") time.sleep(0.2)
Cleanup on Exit
When
Ctrl+Cis pressed, the program turns off all LEDs, cleans up GPIO state, and closes the SPI interface.except KeyboardInterrupt: pass finally: for pin in led_pins: GPIO.output(pin, GPIO.LOW) GPIO.cleanup() spi.close()
