4.1.7 Smart Fan(MCP3008)
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPICE0 |
Pin 24 |
10 |
8 |
SPIMOSI |
Pin 19 |
12 |
10 |
SPIMISO |
Pin 21 |
13 |
9 |
SPISCLK |
Pin 23 |
14 |
11 |
GPIO22 |
Pin 15 |
22 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
Experimental Procedures
Step 1: Build the circuit.
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Get into the folder of the code.
cd ~/raphael-kit/python
Step 4: Run.
sudo python3 4.1.10-2_SmartFan.py
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
import math
# Pin configuration
BTN_PIN = 22 # Button GPIO (physical pin 15)
MOTOR_IN1 = 5 # Motor forward
MOTOR_IN2 = 6 # Motor backward
MOTOR_EN = 13 # PWM enable pin
# GPIO setup
GPIO.setmode(GPIO.BCM)
GPIO.setup(BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(MOTOR_IN1, GPIO.OUT)
GPIO.setup(MOTOR_IN2, GPIO.OUT)
GPIO.setup(MOTOR_EN, GPIO.OUT)
# PWM setup for motor speed control
pwm = GPIO.PWM(MOTOR_EN, 1000) # 1kHz frequency
pwm.start(0)
# Initialize SPI for MCP3008
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CE0
spi.max_speed_hz = 1000000 # 1 MHz
# Global variables
level = 0
currentTemp = 0
markTemp = 0
def read_adc(channel):
return -1
return value
def temperature():
analogVal = read_adc(0)
Vr = 3.3 * analogVal / 1023.0
Rt = 10000.0 * Vr / (3.3 - Vr)
tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0)))
Cel = tempK - 273.15
return Cel
def motor_run(level):
if level == 0:
GPIO.output(MOTOR_IN1, GPIO.LOW)
GPIO.output(MOTOR_IN2, GPIO.LOW)
pwm.ChangeDutyCycle(0)
return 0
if level >= 4:
level = 4
GPIO.output(MOTOR_IN1, GPIO.HIGH)
pwm.ChangeDutyCycle(level * 25) # Map level (1–4) to 25%–100%
return level
def changeLevel(channel):
global level, currentTemp, markTemp
print("Button pressed")
level = (level + 1) % 5
markTemp = currentTemp
# Add event detection for button press
GPIO.add_event_detect(BTN_PIN, GPIO.FALLING, callback=changeLevel, bouncetime=300)
def main():
markTemp = temperature()
currentTemp = temperature()
if level != 0:
if currentTemp - markTemp <= -2:
level -= 1
elif currentTemp - markTemp >= 2:
if level < 4:
level += 1
level = motor_run(level)
time.sleep(0.2)
main()
finally:
pwm.stop()
GPIO.cleanup()
spi.close()
Code Explanation
Import required modules:
RPi.GPIOfor GPIO control (button and motor),spidevfor communicating with MCP3008 ADC,timefor delays,mathfor temperature calculation using logarithmic functions.
#!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time import math
Set up GPIO pins:
Button on GPIO22 (with internal pull-up),
Motor control using GPIO5 (forward), GPIO6 (backward), and GPIO13 (PWM enable).
BTN_PIN = 22 MOTOR_IN1 = 5 MOTOR_IN2 = 6 MOTOR_EN = 13 GPIO.setmode(GPIO.BCM) GPIO.setup(BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP) GPIO.setup(MOTOR_IN1, GPIO.OUT) GPIO.setup(MOTOR_IN2, GPIO.OUT) GPIO.setup(MOTOR_EN, GPIO.OUT) pwm = GPIO.PWM(MOTOR_EN, 1000) pwm.start(0)
Initialize SPI communication to the MCP3008 (Bus 0, Chip Enable 0) at 1 MHz.
spi = spidev.SpiDev() spi.open(0, 0) spi.max_speed_hz = 1000000
Define
read_adc()function to read a 10-bit analog value (0–1023) from the specified MCP3008 channel (0–7).def read_adc(channel): if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 0x03) << 8) | adc[2] return value
Define
temperature()function to:Convert analog voltage to resistance,
Apply the Steinhart–Hart equation to compute temperature in Celsius.
def temperature(): analogVal = read_adc(0) Vr = 3.3 * analogVal / 1023.0 Rt = 10000.0 * Vr / (3.3 - Vr) tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0))) Cel = tempK - 273.15 return Cel
Define
motor_run()to:Stop motor at level 0,
Run motor forward at increasing speed based on level 1–4, with PWM duty cycle of 25% to 100%.
def motor_run(level): if level == 0: GPIO.output(MOTOR_IN1, GPIO.LOW) GPIO.output(MOTOR_IN2, GPIO.LOW) pwm.ChangeDutyCycle(0) return 0 if level >= 4: level = 4 GPIO.output(MOTOR_IN1, GPIO.HIGH) GPIO.output(MOTOR_IN2, GPIO.LOW) pwm.ChangeDutyCycle(level * 25) return level
Define
changeLevel()callback for button press to:Increase the motor level cyclically (0 to 4),
Record the current temperature as the new baseline.
def changeLevel(channel): global level, currentTemp, markTemp print("Button pressed") level = (level + 1) % 5 markTemp = currentTemp GPIO.add_event_detect(BTN_PIN, GPIO.FALLING, callback=changeLevel, bouncetime=300)
Define
main()loop to:Monitor temperature change relative to the marked temperature,
Decrease level if temperature drops by 2°C or more,
Increase level if it rises by 2°C or more,
Adjust motor speed accordingly every 0.2 seconds.
def main(): global level, currentTemp, markTemp markTemp = temperature() while True: currentTemp = temperature() if level != 0: if currentTemp - markTemp <= -2: level -= 1 markTemp = currentTemp elif currentTemp - markTemp >= 2: if level < 4: level += 1 markTemp = currentTemp level = motor_run(level) time.sleep(0.2)
Run the main function and ensure proper cleanup on Ctrl+C (stop motor, cleanup GPIO, close SPI).
try: main() except KeyboardInterrupt: pass finally: pwm.stop() GPIO.cleanup() spi.close()
