4.1.6 Magnetic Induction Alarm System
When you get a precious vase, you can make a magnetic induction alarm system for it, no matter who moves it, you can hear the alarm in time.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 4.1.6_MagneticAlarmSystem.py
If the reed switch is affected by the magnet (for example, the reed switch is placed on the base and the magnet is placed in the vase), the object is safe. At this time, the reed switch is in the closed state, and the buzzer is silent. After removing the magnet (such as the vase being stolen), the reed switch is not affected by the magnetic, the switch opens, and the buzzer sounds an alarm.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
BeepPin = 27
ReedPin = 17
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(BeepPin, GPIO.OUT, initial=GPIO.HIGH)
GPIO.setup(ReedPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
def loop():
if GPIO.input(ReedPin) == 0:
GPIO.output(BeepPin, GPIO.HIGH)
GPIO.output(BeepPin, GPIO.LOW)
time.sleep(0.1)
time.sleep(0.1)
def destroy():
GPIO.cleanup()
if __name__ == '__main__':
setup()
loop()
destroy()
Code Explanation
def loop():
time.sleep(0.1)
time.sleep(0.1)
We judge the state of the reed switch in the main loop. If the reed switch is closed, the buzzer does not work; otherwise, the buzzer beeps.
