4.1.4 Automatic Capture Camera
When you are out, the little squirrels in the woods might visit your windowsill. Let’s make a automatic capture camera to leave pictures of these little cuties!
../_images/3.1.18components.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Camera Module
PIR Motion Sensor Module
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
../_images/1.1.18_schematic.png
Experimental Procedures
Before this project, you need to make sure you complete 3.1.1 Photograph Module .
Step 1: Build the circuit.
../_images/3.1.18fritzing.png
Step 2: To connect the camera module and complete the configuration, please refer to: Camera Module.
Step 3: Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: Connect your Raspberry Pi. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to Remote Desktop.
Step 4: Open a Terminal and get into the folder of the code.
cd ~/raphael-kit/python/
Step 5: Run.
sudo python3 4.1.4_AutomaticCaptureCamera.py
After the code runs, PIR will detect the surrounding environment, and if it senses the little squirrel passing by, the camera will take a photo. The photo interval is 3 seconds, and the total number of photos taken will be displayed through the print window.
There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end.
../_images/PIR_TTE.png
You can also open 4.1.4_AutomaticCaptureCamera.py in the ~/raphael-kit/python/ path with a Python IDE, click Run button to run, and stop the code with Stop button.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import os
import RPi.GPIO as GPIO
# USER DIRECTORY
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
# GPIO SETUP
PIR_PIN = 17  # PIR motion sensor connected to GPIO17
GPIO.setmode(GPIO.BCM)
GPIO.setup(PIR_PIN, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
# CAMERA SETUP
camera = Picamera2()
camera.start()
print("Motion detection started. Press Ctrl+C to exit.")
# MAIN LOOP
    i = 1
        if GPIO.input(PIR_PIN) == GPIO.HIGH:
            filename = f"{user_home}/capture{i}.jpg"
            camera.capture_file(filename)
            print(f"Motion detected. Saved image #{i}: {filename}")
            time.sleep(3)
            i += 1
            print("waiting")
            time.sleep(0.5)
# KEYBOARD INTERRUPT
    print("\nKeyboard interrupt received. Exiting program...")
# CLEANUP
finally:
        camera.close()
    except:
    GPIO.cleanup()
    print("Program exited cleanly.")
Code Explanation
  1. Reads the current user’s home directory for saving captured images.
    This obtains the active user’s name and builds a full path to the home directory.
  2. Sets up GPIO and configures the PIR motion sensor on GPIO17 as an input.
    PIR_PIN = 17
    Using a pull-down resistor ensures that the pin reads LOW when no motion is detected.
  3. Initializes the Picamera2 instance and starts the camera.
    camera.start()
    The camera is activated so it can capture images immediately when motion is detected.
  4. Detects motion by reading the PIR sensor input state.
    When the PIR senses movement, it outputs a HIGH signal, triggering the capture process.
  5. Captures an image and saves it using a sequential file number.
    Each detection saves a new image as capture1.jpg, capture2.jpg, and so on.
  6. Delays for three seconds after a motion-triggered capture.
    time.sleep(3)
    This prevents multiple images from being taken too quickly after a single motion event.
  7. Prints “waiting” when no motion is detected and checks again after a short delay.
        print("waiting")
        time.sleep(0.5)
    This ensures constant monitoring while reducing unnecessary CPU usage.
  8. Handles keyboard interruption (Ctrl+C) to exit the program safely.
    A clean exit message is printed when the user stops the program manually.
  9. Releases camera and GPIO resources before exiting.
    finally:
        camera.close()
        GPIO.cleanup()
    This ensures the camera shuts down properly and all GPIO pins return to a safe state.
Phenomenon Picture
../_images/4.1.4spycamera.JPG
