3.4 Liquid Crystal Displayď
LCD1602 is a character type liquid crystal display, which can display 32 (16*2) characters at the same time.
As we all know, though LCD and some other displays greatly enrich the man-machine interaction, they share a common weakness. When they are connected to a controller, multiple IOs will be occupied of the controller which has no so many outer ports. Also it restricts other functions of the controller. Therefore, LCD1602 with an I2C bus is developed to solve the problem.
Here we will use the I2C1 interface to control the LCD1602 and display text.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Schematic
Open the
3.4_liquid_crystal_display.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
Here you need to use the library called
lcd1602.py, please check if it has been uploaded to Pico W, for a detailed tutorial refer to 1.4 Upload the Libraries to Pico.
from machine import I2C, Pin
from lcd1602 import LCD
# Initialize I2C communication;
# Create an LCD object for interfacing with the LCD1602 display
lcd = LCD(i2c)
# Display the first message on the LCD
# Use '\n' to create a new line.
string = "SunFounder\n LCD Tutorial"
lcd.message(string)
# Wait for 2 seconds
time.sleep(2)
# Clear the display
lcd.clear()
# Display the second message on the LCD
string = "Hello\n World!"
lcd.message(string)
# Wait for 5 seconds
time.sleep(5)
# Clear the display before exiting
lcd.clear()
After the program runs, you will be able to see two lines of text appear on the LCD in turn, and then disappear.
When the code is running, if the screen is blank, you can turn the potentiometer on the back to increase the contrast.
How it works?
Setting up I2C Communication
The
machinemodule is used to set up I2C communication. SDA (Serial Data) and SCL (Serial Clock) pins are defined (pin 20 and 21 respectively), along with the I2C frequency (400kHz).from machine import I2C, Pin i2c = I2C(1, sda=Pin(6), scl=Pin(7), freq=400000)
Initializing the LCD Display
The
LCDclass from thelcd1602module is instantiated. This class handles the communication with the LCD display through I2C. AnLCDobject is created using thei2cobject.For more usage of the
lcd1602library, please refer tolcd1602.py.from lcd1602 import LCD lcd = LCD(i2c)
Displaying Messages on the LCD
The
messagemethod of theLCDobject is used to display text on the screen. The\ncharacter creates a new line on the LCD. Thetime.sleep()function pauses execution for a specified number of seconds.string = "SunFounder\n LCD Tutorial" lcd.message(string) time.sleep(2) lcd.clear()
Clearing the Display
The
clearmethod of theLCDobject is called to clear the text from the display.lcd.clear()
Displaying a Second Message
A new message is displayed, followed by a delay and then clearing the screen again.
string = "Hello\n World!" lcd.message(string) time.sleep(5) lcd.clear()
