3.5 Small Fan
Now we use the TA6586 to drive the DC motor to make it rotate clockwise and counterclockwise. Since the DC motor requires a relatively large current, for safety reasons, here we use a power module to supply power to the motor.
ITEMS IN THIS KIT
Kepler Kit
450+
Kepler Ultimate Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico W
Micro USB Cable
Jumper Wires
Several
TA6586 - Motor Driver Chip
DC Motor
Li-po Charger Module
Power Pack
Battery Holder
Schematic
sch_motor
  • Since DC motors require a high current, we use a Li-po Charger module to power the motor here for safety reasons.
  • Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your battery and circuitry.
wiring_motor
  • Open the 3.5_small_fan.py file under the path of kepler-kit-main/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
import machine
import utime
motor1A = machine.Pin(14, machine.Pin.OUT)
motor2A = machine.Pin(15, machine.Pin.OUT)
def clockwise():
    motor1A.high()
    motor2A.low()
def anticlockwise():
    motor1A.low()
    motor2A.high()
def stopMotor():
    motor1A.low()
    motor2A.low()
    clockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
    anticlockwise()
    utime.sleep(1)
    stopMotor()
    utime.sleep(1)
Once the program is running, the motor will rotate back and forth in a regular pattern.
  • If the motor is still spinning after you click the Stop button, you need to reset the RUN pin on the Pico W with a wire to GND at this time, and then unplug this wire to run the code again.
  • This is because the motor is operating with too much current, which may cause the Pico W to disconnect from the computer.
wiring_run_reset
